I am stuck on a seemingly simple operation. I am using the 24FC256 I2C EEPROM where the A0,A1,and A2 pins are wired to ground, creating an I2C address of 0x50. I am able to create my EEPROM object just fine but the issue comes into play when I try to do EEPROM.Write(int address, byte data). I receive an ArgumentException from a command such as Write(0,bytes[1]) where bytes[1] is an int converted.
bytes[1] may not be what you think it is. That is the most likely argument that is causing an exception. Just test simply - write a block of data, 0 in address 0, 1 in 1 etc, and then read it back. Prove the simple stuff works, then move on to writing your own data, then move on to reading your own data back
And yes I created my own thread because although the one I originally posted in was the exact same setup, I realized people are MUCH faster to respond to a new topic. I will refrain from posting in multiple places…unless I am stuck and in an extreme hurry like today. Here is the driver I have been using, can’t find the original link because all of code share seems broken / missing.
Copyright 2010 Christophe Gerbier
Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software distributed under the License is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License for the specific language governing permissions and limitations under the License.
namespace PandaMotorsDriver
/// <summary>
/// PandaEEprom class
/// </summary>
public class PandaEEprom
private static I2CDevice.Configuration I2CConfig;
private static I2CDevice I2C;
/// <summary>
/// Initializes a new instance of the <see cref="PandaEEprom"/> class.
/// </summary>
public PandaEEprom(byte Address, int ClockRateKHz)
I2CConfig = new I2CDevice.Configuration((ushort)(Address >> 1), ClockRateKHz); // 400 KHz, A0-A2 shorted to ground (by design) = 0x50
I2C = new I2CDevice(I2CConfig);
/// <summary>
/// Writes a one byte data at the specified address.
/// </summary>
/// <param name="Address">The address to write to.</param>
/// <param name="data">The byte to write</param>
public void Write(int Address, byte data)
var xActions = new I2CDevice.I2CTransaction[1];
xActions[0] = I2CDevice.CreateWriteTransaction(new byte[] { (byte)(Address >> 8), (byte)(Address & 0xFF), data });
I2C.Execute(xActions, 1000);
Thread.Sleep(5); // Mandatory after each Write transaction !!!
/// <summary>
/// Writes the string Text at the specified address.
/// </summary>
/// <param name="Address">The starting address to write to</param>
/// <param name="Text">The text to write to EEprom</param>
public void Write(int Address, string Text)
var Addr = Address;
byte[] buffer = System.Text.Encoding.UTF8.GetBytes("00"+Text); // the "00" string reserves the room for the 2 bytes address that follows
buffer[0] = (byte)(Address >> 8);
buffer[1] = (byte)(Address & 0xFF);
xActions[0] = I2CDevice.CreateWriteTransaction(buffer);
/// <summary>
/// Reads the specified address.
/// </summary>
/// <param name="Address">The address to be read</param>
/// <returns>One byte from the EEprom</returns>
public byte Read(int Address)
var Data = new byte[1];
xActions[0] = I2CDevice.CreateWriteTransaction(new byte[] { (byte)(Address >> 8), (byte)(Address & 0xFF) });
xActions[0] = I2CDevice.CreateReadTransaction(Data);
return Data[0];
Ok thank you I will implement that now. To write a 0 to block 0 like you said, is that just Write(0,0)? I get really confused with all these different address formats.
It’s unlikely to be the 7-bit vs 8-bit address thing, but it could be… that’s why the debug output of transactions working or not is important. I looked at the old doco page https://old.ghielectronics.com/docs/12/i2c to see what I had modified in the earlier GHI doco for transaction checking, and there’s also text there about 7-bit addressing.
For RegisterValue, look at the full code example in the link above
It’s either addressing (and you’ll see that because all transactions fail, none work - but that could also identify you have a wiring issue) or it’s that you’re passing the wrong data in, hence my suggestion to go back to simple steps first.
Would I be able to create the EEPROM I2C Object if there was a wiring issue? In other interfaces it usually gives a hardware error. I actually had a loose wire before I posted this but once I pushed it in I stopped getting the hardware exception and began getting the ArgumentException we have been discussing.
I tried writing Write(0,bytes[0]) where bytes[0]=BitConverter(0); and still get the same error.
One possible thing it could be is the fact I didn’t use pull down resistors on A0-A2 - my electrical engineer said it wouldn’t make a difference if I went straight to ground but maybe he was wrong. It’s such a simple chip to set up…that’s the only mistake I can see. Much easier than that damned L6470…and soon I will be damning the FT232’s tininess.
As far as wiring goes: I have A0,A1,A2,Vss, and WP (enables writing when low) all wired to ground (Pins 1,2,3,4, and 7). Vcc (pin 8) is +5V, SCL goes to the SCL pin on uC, SDA goes to SDA pin on uC and is pulled high with a 2k ohm resistor to Vcc.
Literally the only deviation is lack of pulldown resistors on Pins 1-3.
