Maybe the EEPROM itself is bad?
Yes, it will.
Well because a READ of the EEPROM requires you to WRITE to the EEPROM Control registers, and then read back the data you want.
You had one simple test to do that would tell you whether you were talking to the eeprom or not - add the debugging in on the return from execute. Whats the status of that???
I added the code you told me to but that part gets skipped over after the exception is triggered. It fails at Execute according to the stack trace.
I double checked the wiring and everything looks good and corresponds to the instructions in the datasheet.
then clearly you are still passing incorrect parameters to the call !
step back to the basics please, write a stand alone app that just passes âgoodâ values in.
I have had this in a standalone app the whole time. All I am doing is putting a 0 into a byte array and writing that respective array index to either address 0 or 1. Still getting the same error. Iâll post my code in a few minutes.
Does SCL need a pull up resistor? The datasheet only says SDA needs a pull up but only has one sentence about SCL.
SCL is driven by the micro, so no it does not need pull-up/down
I read online that since its open drain it needs one or else it cant be pulled high to initiate a start/stop flag, I havenât had a chance to try it though because I had to help make 475 MIMICs lol, CRAZY.
Do you have any other suggestions?
SDA is open drain. SCL is an input, and nowhere in the datasheet does it say it is open drain
Yes, SHOW US YOUR TEST APP CODE.
This is the first free moment I have had all dayâŚthey had me on assembly for a million dollar order.
namespace MFConsoleApplication2
try
int y = 1;
// var bytes = new byte[TabsFinal.Length * sizeof(int)];
// bytes= BitConverter.GetBytes(y);
//for (int x = 0; x < Tabs.Length; x++)
// Array.Copy(BitConverter.GetBytes(TabsFinal[x]), 0, bytes, x * sizeof(int), sizeof(int));
EEPROM memory = new EEPROM(0x50, 1000);
memory.Write(0, "10");
// for (var j = 0; j < bytes.Length; j++)
// memory.Write(j, bytes[1]);
// Thread.Sleep(5);
// var buffer = memory.Read(0x50);
// var results=new int[buffer.Length/sizeof(int)];
//for (var i=0; i<results.Length;i++){
//results[i]=BitConverter.ToInt32()
catch(Exception ex)
{ Debug.Print(ex.ToString()); }
/// <summary>
/// EEprom class
/// </summary>
public class EEPROM
private static I2CDevice.Configuration I2CConfig;
private static I2CDevice I2C;
/// <summary>
/// Initializes a new instance of the <see cref="EEPROM"/> class.
/// </summary>
public EEPROM(byte Address, int ClockRateKHz)
I2CConfig = new I2CDevice.Configuration((ushort)(Address >> 1), ClockRateKHz); // 400 KHz, A0-A2 shorted to ground (by design) = 0x50
I2C = new I2CDevice(I2CConfig);
/// <summary>
/// Writes a one byte data at the specified address.
/// </summary>
/// <param name="Address">The address to write to.</param>
/// <param name="data">The byte to write</param>
public void Write(int Address, byte data)
var xActions = new I2CDevice.I2CTransaction[1];
xActions[0] = I2CDevice.CreateWriteTransaction(new byte[] { (byte)(Address >> 8), (byte)(Address & 0xFF), data });
// I2C.Execute(xActions, 1000);
// Thread.Sleep(5); // Mandatory after each Write transaction !!!
if (I2C.Execute(xActions, 1000) == 0)
Debug.Print("Failed to perform I2C transaction");
var Data = new byte[1];
xActions[0] = I2CDevice.CreateReadTransaction(Data);
Thread.Sleep(5);
Debug.Print("Register value: " + Data[0].ToString());
/// <summary>
/// Writes the string Text at the specified address.
/// </summary>
/// <param name="Address">The starting address to write to</param>
/// <param name="Text">The text to write to EEprom</param>
public void Write(int Address, string Text)
var Addr = Address;
byte[] buffer = System.Text.Encoding.UTF8.GetBytes("00" + Text); // the "00" string reserves the room for the 2 bytes address that follows
buffer[0] = (byte)(Address >> 8);
buffer[1] = (byte)(Address & 0xFF);
xActions[0] = I2CDevice.CreateWriteTransaction(buffer);
//I2C.Execute(xActions, 1000);
Thread.Sleep(5);
/// <summary>
/// Reads the specified address.
/// </summary>
/// <param name="Address">The address to be read</param>
/// <returns>One byte from the EEprom</returns>
public byte Read(int Address)
xActions[0] = I2CDevice.CreateWriteTransaction(new byte[] { (byte)(Address >> 8), (byte)(Address & 0xFF) });
return Data[0];
EEPROM memory = new EEPROM(0x50, 400);
And
I2CConfig = new I2CDevice.Configuration((ushort)Address, ClockRateKHz); // 400 KHz, A0-A2 shorted to ground (by design) = 0x50
Slight improvement with matching the clock frequencies to 400 - it now does not give me the argument exception, it actually makes it through the if else statements and triggers âFailed I2C transaction.â Still not working but one step closer now, thank you.
I lowered Vcc down to 2 V to match the 400 kHz clock speed. Not sure what to do next.
I removed the left shift like you did and it successfully wrote and returned a register value. Not sure if it was the correct value yet but yay!
I wrote a 0 and it returned a register value of 255. Thats not right is it?
Still stuck on this. Not sure why I only get 255 back
I successfully wrote a 1 to address 5 but now I canât get anything else to write it keeps reading back the same valuesâŚ46 255 255 255 1. I also wrote the 46 when trying to write multiple bytes but that was the only one that actually wrote and havenât gotten past that. attached is my screen shot of my SDA line, havenât gotten the second channel to work simultaneously on the scope yet so I canât show SCL at the same time until I get some help tomorrow.
I think I have a 24LC256 around here somewhere but I canât lay my hands on it to do a benchmark test to compare - Iâm still searching (but if you saw my bench youâd understand that itâs non trivial )
So can you please point out WHY you did that? Have you un-done it? From the Microchip datasheet for 24XX256 I can see 400khz maximum is fine for 2.5v to 5.5v, so going to 2v is out of spec. http://ww1.microchip.com/downloads/en/DeviceDoc/20001203U.pdf
edit: I see you have the FC part. That does nemtion having a 1.7v to 2.5v power for 400khz (max) so I assume that you can still power with 3.3v where the max is listed as 1000khz, and run it at 400khz which is below the maximumâŚ
and can you confirm what you did with the WP pin? Tied to GND or VCC?
