Here is 0.12.0 version: http://www.bauland.fr/Electron/Firmware/v1.1/Electron11%20Firmware%200.12.0.dfu.zip
I build it but don’t have time to test it. So tell me if there is Something wrong !
Could you please provide a version 1.0.0 of the firmware?
I’ve tried the firmware but Windows says that the USB device has not been recognized. It work with the firmware 0.12.0 but not this one.
i need to check this problem may still not fixed
Take a look here:
another tricks
download
https://docs.ghielectronics.com/hardware/loaders/ghi-bootloader.html
http://files.ghielectronics.com/downloads/Bootloaders/FEZCLR%20Bootloader%20v2.0.4.dfu
and with
http://files.ghielectronics.com/downloads/TinyCLR/Config/TinyCLR%20Config%20Setup%20v1.0.0.msi
you can install FEZ CLR and it will be recognised FEZCLR_FEZCLR
The above firmware does indeed work but your not going to have much fun with it in the real world as the memory mapping is not quite right.
With a couple of changes…
TinyCLR OS v1.0.1 for above is here
with this firmware i’ve got usb unkown
also with source from DEV Branch
but with MASTER Branch seems it was ok , also if i install FEZCLR dfu and install from TinyCLR Config Setup v1.0.0
You have an Electron v1?
If so then that’s probably your issue as v1 had an 8 MHz stay vs 12 KHz for v1.1.
My download is set for 12 MHz
yes the first Electron 1.0 not 1.1
i don’t know what problem have but i face two problems with this master piece
if i build with new dev branch tinyclr have this issues
if i build with old master branch tinyclr have no issues.
Add #define STM32F4_EXT_CRYSTAL_CLOCK_HZ 8000000 to Device.h
thanx a lot
but i make new firmware from G30 with slide modification regards,
just optimized to use full memory / and 411x … instead 401x
now builded from DEV
Whats does
Debug.WriteLine("Used: " + Memory.UsedBytes + " Free: " + Memory.FreeBytes);
Give you.
var freeRam = GHIElectronics.TinyCLR.Native.Memory.FreeBytes;
var usedRam = GHIElectronics.TinyCLR.Native.Memory.UsedBytes;
Debug.WriteLine("free Ram : " + freeRam.ToString() + " - used Ram : " + usedRam.ToString());
free Ram : 41456 - used Ram : 39872
firmware
src for firmware
sample code
https://drive.google.com/drive/folders/1oN0vRiyMlEWja5Lt3hXD85kM2at_o9kw?usp=sharing
Your still missing some ram…
I will email you.
Hi Justin,
I’ve tried your last firmware (you sended it to me via email) and it worked well with enough memory for my project. If you are able to free more memory let me (us) know!.
Thank you.
hmmm I must have v1.0 device too… How do you tell difference?
