I’ve been using my WiFI modeule with a spider II for about a week for development. I have been opening sockets, sending data, no probs, until last night. :’(
Suddenly, the wifi module’s class is not returning from the constructor during initialization. Took me a while to narrow it down to that module, but the program loads if I un-wire it in the diagram (or remove it from the project entirely).
Does this mean my wifi module died, or is there some way I can reset/reflash it?
here’s where you will need to install the pre-release SDK. There were some wifi related changes that you might need. From Step 4 of .NET Micro Framework – GHI Electronics, grab the GHI Electronics NETMF SDK 2016 R1 Pre-Release 2 SDK.
@ jasells - @ Brett is right, the latest pre-release contains some changes to Wi-Fi that can help you recover from some problems with it. Specifically, after you run the constructor but before you call Open, call UpdateFirmware once to reflash the Wi-Fi module. You’ll need to do that in a Micro Framework Console App, not Gadgeteer. https://www.ghielectronics.com/docs/30/networking#3121 has a simple example.
Am I setting the right pins for a FEZ Spider II? I tried to find some info on what pins to map, but… not sure where to find that info. Hopefully, my module isn’t dead.
Look at the schematic for the WiFiRS9110 module. It will show you how the socket pins are connected to the IC.
For instance, is the Chip Select pin is connected to Pin6 of the socket, then you would use GHI.Pins.FEZSpiderII.Socket6.Pin6 for the pin assignment in the module driver constructor. The same follows for the remaining required pins.
Hi:
I am using a Raptor, VB, gadgeteer, 4.3.8.1. The RS21 is connected to socket 9.
At the beginning of my program, the first line of ProgramStarted is
wifiRS21.NetworkInterface.Open()
The result is
#### Exception GHI.Networking.WiFiRS9110+HardwareFailureException - 0x00000000 (1) ####
#### Message:
#### GHI.Networking.WiFiRS9110::UpdateInternalMacAddress [IP: 001c] ####
#### GHI.Networking.WiFiRS9110::OnOpening [IP: 000a] ####
#### SpaController.SpaController.Program::ProgramStarted [IP: 0018] ####
A first chance exception of type ‘GHI.Networking.WiFiRS9110.HardwareFailureException’ occurred in GHI.Networking.dll
What are the particulars for solving this issue which it seems is in the firmware?
Did you already use the module (the one you try to use, not in gerneral)? I experienced that new modules doesn’t work until you update the firmware once (but I only used the bare modules, not the Gadgeteers), maybe that helps. Just call
once. Based on my experiences, the device has to be reset after updating the Wifi-firmware to get it working properly.
@ gix, @ John:
Thanks for your replies. If I make updatefirmware the first line of code executed, I get the same result:
Using mainboard GHI Electronics FEZ Raptor version 1.0
Program Started
#### Message:
#### GHI.Networking.WiFiRS9110::ThrowFailure [IP: 0007] ####
#### SpaController.SpaController.Program::ProgramStarted [IP: 0010] ####
@ rockybooth - Can you start a new Micro Framework Console Application, not Gadgeteer, and just add the WiFi RS21 constructor and the call to UpdateFirmware?
