[quote]Photon
The Photon is a $19 tiny Wi-Fi development kit for creating connected projects and products. It’s easy to use, it’s powerful, and it’s connected to the cloud.
Yeah, I’ve been waiting for this to come out. I saw a few spec sheets a year ago showing that they were working with muRata to integrate the Broadcom wifi and an stm32 mcu. This CPU has the ram and flash to support .net mf so this certainly has my attention. Also, they have surface mount modules with mcu, wifi, antenna, and FCC certification for $12 each. All we need is a wifi driver. I’ll be looking at the Broadcom API soon to get a feel for how hard it would be. It might also need a TCP stack.
I’d really like to see Microsoft pick two of the mcu+wifi integrated solutions and support them as reference designs. This device (or ti cc3200) and another with more flash and ram perhaps. One that is inexpensive and one that is more beefy.
I’m sure the Edison will be a reference device for Microsoft’s embedded OS. We need one too.
Holy Cow! My bad! I got ElectricImp confused with SparkIO. Believe it or not, ElectricImp is doing an almost identical device with the same Broadcom wifi paired with the stm32f405! It looks like SparkIO did not use muRata.
Yeah, the MCU support is not a concern. This is the same CPU as the one in the Netduino 2, but I think the Spark Photon has more RAM and Flash. So, we probably just need to update the scatterfile and the platform file. The real work would be in that Wifi adapter.
With both of these devices using NET MF compatible MCUs and the same Wifi, there will be a lot of incentive to get this driver integrated. Like I said, if Microsoft wants to put IoT with NET MF, having them get these components to work would be a great place to start.
I ordered one of these Spark Photons. As soon as I get it, I’ll throw.NET MF on there just because I can
I’m guessing that manufacturers that integrated the Broadcom chip are keeping things simple by sticking with the same family as the reference MCU. That’s why the SparkIO, ElectricImp, muRata and the Broadcom Reference all use the STM32.
That’s what really raised my eyebrows. WiFi and a micro for 12 bucks! If somebody we’re to work out a driver for the wireless, I, and probably others here, would be happy to donate (some small amount) of cash to incentivise the effort.
@ munderhill - I mean whatever Valkyrie-MT means by his last sentence above. I assume that means getting the WiFi chip to work in Netmf. Doesn’t sound like porting is much of an issue.
[quote=“ransomhall”] I assume that means getting the WiFi chip to work in Netmf.
[/quote]
Yeah, I meant getting the Broadcom wifi to work. One approach (the best and fastest) would be to take Broadcom’s reference implementation in C++ and integrate that into a .Net MF port. The other would be similar to what I did with mIP, which is to open an spi port to the Broadcom chip from managed code and do everything in managed code.
Getting .Net MF to work on this is almost certainly not an issue.
I’m hoping Microsoft will consider doing the integration.
I have the original Spark Core’s and they are great but I hate the online programming setup. Too slow and there is no in circuit debugging.
I’ve tried to setup the JTAG via Netbeans but so far can’t get the debugger to run. I can build and download VIA USB but I really want debugging to work. I hate trying to find issues without single stepping etc.
Has anyone made any progress on getting netmf running on these devices?
Has anyone run into a road block that would tell me it is not going to be very easy to get netmf running?
@ terrence - I am looking at it with Justin, but the problem is that the necessary pins to load the NETMF firmware and bootloader are not accessible from the outside. I am going to remove the metal shield that covers everything to see if the pins are then accessible. If there are, we’ll be halfway there…
