Hello,
has anyone experience in using the RC522-module for reading MyFaire-Cards?
We use this module with the Netduino and it works fine. Now we wanted to transform into TinyCLR with a FEZ.
It has a SPI-interface and we have adapted the software to TinyCLR. We sent the same bytes but get totally other bytes in reading.
We’ve testet all 4 SPI-modes without success.
Chip select is not set properly perhaps?
can you share rc522 code if possible
It seem to work. If I set it to an other Pin I get other values.
I also deactivated it and activate the pin per programm and get the same result as with CS per SPI-module.
I use this code: mfrc522-netmf/Mfrc522 at master · mlowijs/mfrc522-netmf · GitHub.
With NETDUINO it works perfect. For TinyCLR I’ve made some adaptions, f.e. in TransferSpi and init:
var settings = new SpiConnectionSettings()
ChipSelectType = SpiChipSelectType.Gpio,
ChipSelectLine = FEZ.GpioPin.D9,
Mode = SpiMode.Mode1,
ClockFrequency = 1000 * 1000, //1Mhz
DataBitLength = 8,
var controller = SpiController.FromName(FEZ.SpiBus.Spi1);
_spi = controller.GetDevice(settings);
can you add
var _chipSelectLine = GpioController.GetDefault().OpenPin(FEZ.GpioPin.D9);
_chipSelectLine.SetDriveMode(GpioPinDriveMode.Output);
_chipSelectLine.Write(GpioPinValue.Low);
var spiSettings = new SpiConnectionSettings(_chipSelectLine.PinNumber);
spiSettings.ClockFrequency = 1000*1000;
spiSettings.DataBitLength = 8;
spiSettings.Mode = SpiMode.Mode1;
_spi = SpiDevice.FromId(FEZ.SpiBus.Spi1, spiSettings);
Thank you, but it dosn’t work fpr me.
My compiler didn_t accept a parameter in “SpiConnectionSettings” and “FromId” is unknown.
try this (since i am not before my pc and have no device)
GpioPin _chipSelect = GpioController.GetDefault().OpenPin(FEZ.GpioPin.D9);
_chipSelect.SetDriveMode(GpioPinDriveMode.Output);
_chipSelect.Write(GpioPinValue.Low);
ChipSelectLine = _chipSelect.PinNumber,
DataBitLength = 8,
it dosn’t work because you can’t define the same pin extern and in SPI. I get an exception.
you should enable chip select with write(low) today i’ve got an spi mfrc522 from an friend and buyed online an uart mfrc522 so i will try to make it working driver from link you sent
Did you find anything?
It is possible that the SPI in tinyCLR has a problem? Because as user we have only the init with a few parameter and this I have tested. The chip select should also not be the problem because in the mfrc522 class I can handle CS externally.
I have no idea what I should do to make it run.
I converted sample from your link but device i have do not work even with arduino
please find sample
https://drive.google.com/drive/folders/184LjWKSj9SesGOav9Db30xtfDYeQfDmE?usp=sharing
i tried to convert
such is
GetDevice(…)
initialize chipselect so you dan’t have to initialize before GetDevice
From datasheet (fig. 25) I think this sould be Mode0 and not Mode1 for spi mode.
I have an mfrc522 module, so I would check code and try to communicate with module.
Conversion is nice, but (there is Always a but ! ), in TransferSpi, change TransferSequential to TransferFullDuplex.
In constructor, ssPin initialization is not needed because you can put it in spi settings which is better for time execution.
In mode, my module is working wth mode0 not mode1.
Now I can detect when tag is present or not, and read uid.
WriteBlock doesn’t seem to work but I’m not an expert with RC522. I’ll give others tries tomorrow.
i have no working mfrc522 rfid for now until i get new ones ,so i have no ability to test
and tried to convert as is with adapted changes but as you see it (still have something that missing)
I will try to write a driver for this module but I must go in depth of iso 14443-3 ! But it’s very interesting as a physicist and programmer !
can you publish driver that you corrected from driver above that are able to see if tag presented and show uid
I’am rewriting it from scratch and I don’t have put previous on git.
But I hope have new one for few days.
A first (very simple) version without anticollision and only for 4 bytes uid card.
using System.Diagnostics;
using GHIElectronics.TinyCLR.Devices.Spi;
using Bauland.Others.Constants.MfRc522;
namespace Bauland.Others
/// <summary>
/// </summary>
public class MfRc522
private readonly GpioPin _resetPin;
//private readonly GpioPin _irqPin;
private readonly SpiDevice _spi;
private readonly byte[] _registerWriteBuffer;
private readonly byte[] _dummyBuffer2;
public MfRc522(string spiBus, int resetPin, int csPin/*, int irqPin = -1*/)
_dummyBuffer2 = new byte[2];
_registerWriteBuffer = new byte[2];
var gpioCtl = GpioController.GetDefault();
_resetPin = gpioCtl.OpenPin(resetPin);
_resetPin.SetDriveMode(GpioPinDriveMode.Output);
_resetPin.Write(GpioPinValue.High);
//if (irqPin != -1)
// _irqPin = gpioCtl.OpenPin(irqPin);
// _irqPin.SetDriveMode(GpioPinDriveMode.Input);
// _irqPin.ValueChanged += _irqPin_ValueChanged;
ChipSelectActiveState = false,
ChipSelectLine = csPin,
ClockFrequency = 10_000_000,
DataBitLength = 8,
Mode = SpiMode.Mode0
_spi = SpiController.FromName(spiBus).GetDevice(settings);
HardReset();
SetDefaultValues();
private void SetDefaultValues()
// Set Timer for Timeout
WriteRegister(Register.TMode, 0x80);
WriteRegister(Register.TPrescaler, 0xA9);
WriteRegister(Register.TReloadH, 0x06);
WriteRegister(Register.TReloadL, 0xE8);
// Force 100% Modulation
WriteRegister(Register.TxASK, 0x40);
// Set CRC to 0x6363 (iso 14443-3 6.1.6)
WriteRegister(Register.Mode, 0x3D);
EnableAntennaOn();
private void EnableAntennaOn()
SetRegisterBit(Register.TxControl, 0x03);
//private void EnableAntennaOff()
// ClearRegisterBit(Register.TxControl, 0x03);
public bool IsNewCardPresent(byte[] bufferAtqa)
if (bufferAtqa == null || bufferAtqa.Length != 2) throw new ArgumentException("bufferAtqa must be initialized and its size must be 2.", nameof(bufferAtqa));
StatusCode sc = PiccRequestA(bufferAtqa);
if (sc == StatusCode.Collision || sc == StatusCode.Ok) return true;
return false;
public Uid PiccReadCardSerial()
StatusCode sc = PiccSelect(out Uid uid);
if (sc == StatusCode.Ok)
return uid;
return null;
private StatusCode PiccSelect(out Uid uid, byte validBits = 0)
uid = new Uid();
bool selectDone = false;
int bitKnown = 0;
var uidKnown = new byte[7];
byte[] bufferBack = null;
ClearRegisterBit(Register.Coll, 0x80);
while (!selectDone)
var bufferLength = bitKnown == 0 ? 2 : 9;
var buffer = new byte[bufferLength];
bufferBack = bitKnown == 0 ? new byte[5] : new byte[3];
byte nvb = (byte)(bitKnown == 0 ? 0x20 : 0x70);
buffer[0] = (byte)PiccCommand.SelCl1;
buffer[1] = nvb;
if (bitKnown != 0)
for (int i = 0; i < 4; i++)
buffer[i + 2] = uidKnown[i];
buffer[6] = (byte)(buffer[2] ^ buffer[3] ^ buffer[4] ^ buffer[5]);
var crcStatus = CalculateCrc(buffer, 7, buffer, 7);
if (crcStatus != StatusCode.Ok) return crcStatus;
DisplayBuffer(buffer);
byte validbits = 0;
WriteRegister(Register.BitFraming, 0);
StatusCode sc = TransceiveData(buffer, bufferBack, ref validbits);
if (sc != StatusCode.Ok)
return sc; // TODO: add collision
if (bitKnown >= 32)
// We know all bits
selectDone = true;
uid.UidType = UidType.T4;
uid.UidBytes=new byte[4];
Array.Copy(buffer, 2, uid.UidBytes, 0, 4);
uid.Sak = bufferBack[0];
// All bit are known, redo loop to so SELECT
bitKnown = 32;
// Save
for (int i = 0; i < 4; i++) // 5 is BCC
uidKnown[i] = bufferBack[i];
return StatusCode.Ok;
private void DisplayBuffer(byte[] buffer)
#if DEBUG2
Debug.WriteLine("#Data:");
Debug.WriteLine($"Length: {buffer.Length}");
var str = "";
for (int i = 0; i < buffer.Length; i++)
str += $"{buffer[i]:X2} ";
Debug.WriteLine($"{str}");
#endif
private StatusCode PiccRequestA(byte[] bufferAtqa)
return ShortFrame(PiccCommand.ReqA, bufferAtqa);
private StatusCode ShortFrame(PiccCommand cmd, byte[] bufferAtqa)
byte validBits = 7;
StatusCode sc = TransceiveData(new[] { (byte)cmd }, bufferAtqa, ref validBits);
if (sc != StatusCode.Ok) return sc;
if (validBits != 0)
return StatusCode.Error;
private StatusCode TransceiveData(byte[] buffer, byte[] bufferBack, ref byte validBits)
byte waitIrq = 0x30;
return CommunicateWithPicc(PcdCommand.Transceive, waitIrq, buffer, bufferBack, ref validBits);
private StatusCode CommunicateWithPicc(PcdCommand cmd, byte waitIrq, byte[] sendData, byte[] backData, ref byte validBits, byte rxAlign = 0, bool crcCheck = false)
byte txLastBits = validBits;
byte bitFraming = (byte)((rxAlign << 4) + txLastBits);
WriteRegister(Register.Command, (byte)PcdCommand.Idle);
WriteRegister(Register.ComIrq, 0x7f);
WriteRegister(Register.FifoLevel, 0x80);
WriteRegister(Register.FifoData, sendData);
WriteRegister(Register.BitFraming, bitFraming);
WriteRegister(Register.Command, (byte)cmd);
if (cmd == PcdCommand.Transceive)
SetRegisterBit(Register.BitFraming, 0x80);
StatusCode sc = WaitForCommandComplete(waitIrq);
if (sc == StatusCode.Timeout)
return sc;
// Stop if BufferOverflow, Parity or Protocol error
byte error = ReadRegister(Register.Error);
if ((byte)(error & 0x13) == 0x13) return StatusCode.Error;
// Get data back from Mfrc522
if (backData != null)
byte n = ReadRegister(Register.FifoLevel);
if (n > backData.Length) return StatusCode.NoRoom;
// if (n < backData.Length) return StatusCode.Error;
ReadRegister(Register.FifoData, backData, rxAlign);
DisplayBuffer(backData);
validBits = (byte)(ReadRegister(Register.Control) & 0x07);
// Check collision
if ((byte)(error & 0x08) == 0x08) return StatusCode.Collision;
// TODO:Do CrcA validation if request
if (crcCheck)
public byte GetVersion()
return ReadRegister(Register.Version);
public StatusCode Halt()
byte[] buffer = new byte[4];
buffer[0] = (byte)PiccCommand.HaltA;
buffer[1] = 0;
byte validBits = 0;
StatusCode sc = CalculateCrc(buffer, 2, buffer, 2);
sc = TransceiveData(buffer, null, ref validBits);
if (sc == StatusCode.Timeout) return StatusCode.Ok;
if (sc == StatusCode.Ok) return StatusCode.Error;
return sc;
private StatusCode CalculateCrc(byte[] buffer, int lengthBuffer, byte[] bufferBack, int indexBufferBack)
byte[] shortBuffer = new byte[lengthBuffer];
Array.Copy(buffer, shortBuffer, lengthBuffer);
WriteRegister(Register.DivIrq, 0x04);
WriteRegister(Register.FifoData, shortBuffer);
WriteRegister(Register.Command, (byte)PcdCommand.CalculateCrc);
for (int i = 500; i > 0; i--)
byte n = ReadRegister(Register.DivIrq);
if ((n & 0x04) == 0x04)
bufferBack[indexBufferBack] = ReadRegister(Register.CrcResultLow);
bufferBack[indexBufferBack + 1] = ReadRegister(Register.CrcResultHigh);
return StatusCode.Timeout;
private StatusCode WaitForCommandComplete(byte waitIrq)
for (int i = 2000; i > 0; i--)
byte n = ReadRegister(Register.ComIrq);
if ((n & waitIrq) != 0)
//TODO: not use irq timer
//if ((n & 0x01) == 0x01)
// return StatusCode.Timeout;
private void HardReset()
_resetPin.Write(GpioPinValue.Low);
Thread.Sleep(1);
Thread.Sleep(1);
#region Basic Communication functions
private void WriteRegister(Register register, byte data)
_registerWriteBuffer[0] = (byte)register;
_registerWriteBuffer[1] = data;
_spi.TransferFullDuplex(_registerWriteBuffer, _dummyBuffer2);
private void WriteRegister(Register register, byte[] data)
foreach (var b in data)
WriteRegister(register, b);
public byte ReadRegister(Register register)
_registerWriteBuffer[0] = (byte)((byte)register | 0x80);
_registerWriteBuffer[1] = 0x00;
return _dummyBuffer2[1];
private void ReadRegister(Register register, byte[] backData, byte rxAlign = 0)
if (backData == null || backData.Length == 0) return;
byte address = (byte)((byte)register | 0x80);
byte[] writeBuffer = new byte[backData.Length + 1];
byte[] readBuffer = new byte[backData.Length + 1];
if (rxAlign != 0)
// TODO: to complete
for (int i = 0; i < backData.Length; i++) writeBuffer[i] = address;
_spi.TransferFullDuplex(writeBuffer, readBuffer);
Array.Copy(readBuffer, 1, backData, 0, backData.Length);
private void SetRegisterBit(Register register, byte mask)
var tmp = ReadRegister(register);
WriteRegister(register, (byte)(tmp | mask));
private void ClearRegisterBit(Register register, byte mask)
WriteRegister(register, (byte)(tmp & ~mask));
#endregion
can you post also
