That works anyway. As long as you connect TTL to TTL it’s fine.
Lurch was worried that the UEXT of the mini was not TTL.
As far as I know it is. Unless someone can proof the different?
Why do you want it on UEXT anyway? Why not just connect it to a com port? Is there a reason for that?
[quote]Why do you want it on UEXT anyway[/quote]The UEXT pads are for SPI2 and COM2, which is TTL level (3.3V).
That setup will work. I ran it on the Panda I (which also has the UEXT pads) with my LS20031. The only problem I had at the beginning was that the baudrate per default was 57600 and all NMEA sentences were transferred, so the UART was filling up my memory using the interrupt method before I could process it.
There are some tips on this page to change that if you don’t want to wade through the manual (which you should do, eventually).
file:///C:/Projects/Sparkfun/LS20031%20Documentation/using-the-5hz-locosys-gps-with.htm
The comparison chart for FEZ boards indicates that COM1 on the mini is RS-232 level, not TTL-level. I don’t have a mini, just Panda I’s and II’s, so I can’t be sure.
Just looked at the schematic of the mini - pins 1 and 2 (COM1) are shifted to RS-232 level.
The other COMs are TTL level.
Using the gps-extension code on the code page, I get the following output on my Panda I with my own COM1 printout and the LS20031 connected to COM2 with 57600 baud as above (some of the text I've added. Also the 5 second wait - the window is somewhat further away ;-):
@ Robert, can you check any discounts at Watterott?
Want to order the gps, and some stuff more…
Only, the current problem is, the LS20031 is currently out of stock.
Watterott send me this yesterday: "In about 3 days we receive new ones."
So, the Gps will be tomorrow back in stock
Robert, please let me know, if you can’t get any discounts, no worries, will order anyway
@ Colin I did not mean watterott when I meant discounts
There will be a big shipment from sparkfun, ghi and some other companies soon.
It will be a “buy together” kind of thing…
A teacher of mine will be (or might have) ordering soon too. There will be lower shipping costs for you then (6,75 euros), since it will be sent to his brother which lives in germany.
But since you seem to need it pretty fast I suggest you order right away.
Colin, I have done a full autonomous navigational systems for quite a few projects now, so if you need any help regarding the concepts/want any code feel free to ask.
Xarren, thanks for your help. I don’t want any full (c#) projects, want to figure things out be myself, but have you any code snippets that you think it might help me a lot, instead of searching the whole internet
Well the earth is a sphere, if you’re working with co-ordinates, the standard plane geometry that you’re likely to have learnt at school won’t work very well.
And controller wise, I meant control logic - In most of my projects I use PID control. PID controller - Wikipedia — Its what I’d recommend you use.
Also, are you using the heading from the GPS, or are you going to have an IMU on your project?
PID Controller: “A PID controller calculates an “error” value as the difference between a measured process variable and a desired setpoint. The controller attempts to minimize the error by adjusting the process control inputs.”
Is this controller a piece of programming code or a phycical component? i do think is a programming code.
The main problem with using gps heading is that you don’t have a heading until you start moving, so unless you know which direction you’re facing, you might go straight into something when you start up :).
Xarren, “don’t have a heading until you start moving”, i am aware of this.
I have created a Smartphone application in .NET with GPS connection to test some thing.
Pfff, still waiting for the GPS is back in stock @ watterott (Germany).
Just checked the prices of sparkfun (USA), not a big difference, but the sippingcosts and ETA are big
