@ Squeebee - That’s why you need multiple holey boards and only have one out a time.
Brilliant! Now to hide my credit card bill.
And a question, can I still do serial with this on top of my RP2?
I’m tinkering with XBee and would like to have both connected at once if possible.
@ Squeebee - absolutely
Awesome, I got my RP2 in the mail, just waiting on my Hat.
Jumping ahead: Where would I connect the tx/rx and what COM port will it be, 1?
The hat doesn’t use these pins. You can solder two wires right on the header.
Last time I checked, native serial wasn’t yet supported on IoT core on the pi2. FYI
Pete
@ Pete Brown - correct. We used Linux to test it and look forward to seeing the Windows support.
Ok, and it occurs to me that since I have a Sparkfun USB Explorer, when there is serial support I should be able to do so through USB anyway.
Where is the last version of file http://www.ghielectronics.com/downloads/src/FEZ_HAT.zip ?
@ pierlag - You may have better luck here to find the latest sources for not only the FEZ HAT [url]https://bitbucket.org/ghi_elect/windows-iot/src[/url]
