I am going to respin some of my boards to use native ethernet instead of the ENC28.
I had a quick look at the schematics for the sitcore SOMs and noticed they all use the DP83848 PHY.
Are there more PHYs that are supported? I am mostly interested in the DP83825I for it’s small form factor and simplicity.
At the current timeframe, I can’t take you on your offer… So I will put the DP83848 on my board.
I will send you a sitcore board with the DP83825I some other time!
Is this a external oscillator of some sort? Do you have some specs or a part number for me to use?
Would there be harm in connecting the OE to ground with a pulldown and no connection to an IO pin?
@LucaP, I used: https://www.microchip.com/wwwproducts/en/KSZ8795
Now that I am getting back to this project the part looks like it has 0 stock available. I did the initial prototype last year and built 1 board. I have to make some changes to the board then hopefully it will be ready for production.
The capacitor coupling does allow for isolation on the board if necessary. However, you still have the transformer isolation on the 3 exposed ports.
One benefit of having the switch is that you can do cable diagnostics on each port which can tell you if the cable is open or shorted, as well as the length of the cable.
I will be researching adding Single Pair ethernet port to the currently unused MII/RMII port. Not sure yet if it is possible.
I will probably use the KSZ8784
If I connect my SC20100 to the KSZ8794 trough the RMII interface, I have the same amount of ethernet ports going outwards as you have currently. It saves me from having a PHY and the 8794 is available at the moment.
Formfactor is not so important for me here, I will probably only use the board for development purposes on my desk. For goodies I’d like a (isolated) can transceiver, one of these for MAC address purposes and then a lot of gpio broken out to connect things to on a breadboard. Maybe even some gadgeteer sockets?
