HI,
I know that this topics has been asked several times but I didn’t find the solution there
I am trying to use the Wifi module of the FEZ.
I have updated the Wifi Firmware successfully, reloaded the firmware and reset the WiFi module to its factory settings.
I did the procedure on 2 FEZ.
Then as a test, I did used the example posted on GitHub (Arke64 wifi.cs)
The program hangs up on the wifi.JoinNetwork(SSID,pwd)
Any hints on how to troubleshoot from there.
I get the same with the 2 boards
Another question : Do you have a procedure to update the with on a UC5550 (UCM Dev Board) as I Imagine that this one needs to be updated as well.
