SCM20100A lowest possible power
I have a custom board with the SCM20100E, a power supply and a USB connector. This plugs into another PCB with RS232 driver IC’s and some 1mA LED’s for indicating data on 3 UARTS. The system is battery powered.
I have the Ethernet PHY disabled and powered off. The clock is set to 50%. The software does nothing more than read in serial data to a buffer and outputs this to an acoustic modem approx every 15 mins.
It draws around 60mA when idle and about 63-65 when processing the serial data.
How can I get this power consumption down much lower? I have thought about going to sleep and waking when it detects serial data but concerned I will lose the first few bytes whilst it wakes up.
I am curious on what you see if the processor was put in sleep or hibernate.
I’ll set it up this weekend and let you know.
