A few questions:
- Are there any special considerations for any pins such as required external pullups/pulldown like are documented for the G80? I did not notice any notes in the pinout (yet) here: https://docs.ghielectronics.com/hardware/sitcore/pdfs/sc20100s-pinout.pdf
I did catch the need to pull RESET high.
- Any chance we could get the schematic for the newly built SOM as a sanity check to design against?
All schematics are already published. And you do not need any resistors, not even for reset
isn’t that great?! Where did you see as need for pull up on reset?
Please let us know if you have any further questions.
I see the schematics now, thanks. The page that says the pallet is required is Special Pins here: Special Pins
From what I read, I understand that the pullup is needed for chip versions, not for SOM.
Otherwise, no external pull-up/down resistors are needed on other pins, except I2C.
The chip doesn’t need resistor. We are updating the docs
I’m specifically referring to the SOC/bare chip (no M in the part designator). In retrospect perhaps I should have been more specific in my initial post.
As a follow-up question for @Gus_Issa, would you be willing to share the part # you are using for the 8 Mhz crystal? Properly spec’ing a crystal is a bit of a pain and if possible I would rather just use a known good part than start from scratch.
The processors we use have a permanent internal pull up resistor on the NRST/RESET# pin. No pull up is needed even on SoCs/bare chips.
@rackley: Thank you for pointing out this mistake in docs – will be fixed soon.
On the subject of pins… saw this in the datasheet:
You may be able to eliminate these resistors from the SOM:
This was brought up earlier in the design but I think we decided to keep for now. I completely forgot about it. Thanks for pointing it out.
