The main new features released with this SDK are 4.3 support for our EMX and G120 SoMs, please release notes for details. This of course includes any related products like the FEZ Spider and FEZ Cobra II mainboards.
Typically, the loader is used to update the system components but it can’t be updated itself. However, we are trying to find a way around this but can’t promise anything.
Sounds promising.
We just have started implementing an CAN Application on a G120 based board (using 4.2 of course).
Now I have to tell my college he has to rewrite the CAN code :whistle:
@ Duke Nukem - I accidently swapped the firmware and loader versions for 4.2 devices when changing how they were stored in FEZ Config. No changes were made to 4.2 firmwares or loaders in this release. The actual firmware that will be flashed will show the correct version.
I know several online API docs with frames which have this issue. So I think it’s a problem with the tool GHI uses for generating the API docs.
The Latest Sandcastle Versions generate online API that works without any issues, see here: http://aarpg.net/tinkr/help/html/index.html
