that error says you’ve not got all the files you need !
So, here goes. First up, are you on Windows 7, or earlier? x86 or x64? If you have x64 then your directory path is the same as mine - if not, then you don’t need the “(x86)” piece in the program files directory.
open your CMD prompt
do the instructions from me above, to the point where the DIR TINY* command is.
Then do a DIR, and paste the listing output into your reply. Here’s what mine shows:
C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\ChipworkX\Firmware\Tin
yBooter Updater>dir
Volume in drive C has no label.
Volume Serial Number is AA5E-9B49
Directory of C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Chipwork
X\Firmware\TinyBooter Updater
01/10/11 10:08 PM <DIR> .
01/10/11 10:08 PM <DIR> ..
16/10/10 11:17 AM <DIR> bin
28/09/11 05:43 PM 2,642 ChipworkX_TinyBooter_Updater.bat
28/09/11 05:43 PM 2,101 logfile.log
28/09/11 05:43 PM 158,400 TinyBooterLoader.bin
28/09/11 05:43 PM 946 TinyBooterLoader.tcl
01/10/11 10:08 PM <DIR> USB Tinybooter Updater driver
4 File(s) 164,089 bytes
4 Dir(s) 17,184,919,552 bytes free
Then do a DIR /S, and paste the listing output into your reply. Here’s the end of mine:
Total Files Listed:
18 File(s) 2,756,972 bytes
26 Dir(s) 17,184,800,768 bytes free
Yours should be almost exactly the same ( only almost because I am using the SDK1.0.16 version, that has firmware 4.1.7.0 version, and I think 4.1.7.1 is out but i haven’t updated).
then do a DIR BIN\SAM* and check the output is something like this…
X\Firmware\TinyBooter Updater\bin
15/10/10 11:10 AM 2,273,410 sam-ba_cdc_2.9.xp_vista.exe
1 File(s) 2,273,410 bytes
0 Dir(s) 17,180,545,024 bytes free
that should show us you have what appears to be the right file-set available to you.
Next !
