What do I have to change for the Flash and RAM other than the size in the files @Justin listed? Is the base address different? I am not sure how to tell
Those are xml files inside tinyclr tinyboot folders
And you need to adjust iram to 0x00018000 on those files
Yes I already took care of changing iram to 0x0001800 in the xml files, is there any other value that must be changed?
I belive no more changes after modifiying those files from nucleo411 to g30
What about the names of the solutions/headers files?
This mean you should rename all words STM32F411NUCLEO with G30 on header file G30 (include folder name on solution) and on each dotNet.proj inside files
Just the dotNET.proj files inside the solution’s folder right?
Or just on header and on usb file rename STM32F411NUCLEO with G30
Yes just inside solution folder
@valon_hoti_gmail_com Ok It built but saw some red right at the end before the window closed, I am not sure what it said / if there was an error.
Open cmd and run batch file from cmd
And you will be able to see what error say or check inside solution folder log file if was created
Check tinyclr.proj and tinybooter.proj did are there something that you did not replaced.
I can’t find anything wrong
can you attach your solution as zipped file
ok I sent it.
The STM34F11NUCLEO solution compiled fine…maybe I mis-typed somewhere…
