PipBoy 2012
I want one :slight_smile:
Very very very cool!
How are you mapping the movements on the image? Using the lat/lon, or calculating the difference from current/previous positions and scaling that to map?
Also how are you powering the device?
Awesome!
The mapping is done with Lat/Lng. The GPS spits out GPS lat/lng (obviously) and I convert that to map lat/lng in the driver to work w google maps. Then I take a print screen of a map, mark the coordinates and the top left and bottom right corners and use that to plot the point in the image. I also modify the living daylights out of the image to look more fallout like. Each road was redraw by hand and half a dozen filters/effects applied.
It’s powered by a 2200mAh LiPo with a battery life of around 36hrs of max use (gps always looking for a fix, LCD constantly writing, and LED on). More like 2-3days normal usage.
@ Gus, get the uSD online and I might just make you one :wink:
This? http://www.ghielectronics.com/catalog/product/359
Yes but working w the Cerb40
Nice job. You’ve given me some (hopefully good) ideas!
One quick question about that GPS module - how does the reception change if it’s not exposed through the box?
@ mhectorgato - I haven’t played with that too much, though I am sure it would dampen the signal a bit. The truth is the document for the GPS module really sells itself short. I remember reading it would not get a lock inside and the horrible lock times it had, but i figured that was good enough for this little pet project.
I was pleasantly surprised that neither of those were really true. There have been time I waited a very long time on a cold boot, but adding the RTC battery to it (Adafruit ships their board with a coin cell holder you can solder onto the board) fixed that right up, and I’ve never had a problem getting a lock in doors.
Outside I can usually get 9+ satellites where inside I almost always stay at 7. So it would be a fair guess to say that in the outdoors with the GPS unit fully blocked by the enclosure you’d see roughly the same.
Thanks for the report.
Ransomhall is working on a module based on the same chip/antenna. Sounds like that will give me the performance I hoped for.
@ Skewworks - I saw this and thought about you :slight_smile:
http://shirt.woot.com/offers/condition-fleshwound?utm_source=Daily+Digest&utm_campaign=df24a58aa2-Daily+Digest+-+20120710+-+Shirt.Woot&utm_medium=email#tracked
@ ianlee74 - Monty Python [em]and[/em] Fallout? Brilliant!
Cool PipBoy project on instructables
I’ve got the pip-boy edition of fallout 4 coming in Nov. You can be sure I’ll hack it. :smiley:
@ Skewworks - Oh, man! I have missed that. Not available anymore :frowning:
Don’t feel bad, I was checking for it daily and missed it. Had to pay double on ebay.
It is more like five times more now on e-bay!
:open_mouth: :open_mouth: :open_mouth:
Anybody from Bethesda here? :wink:
Bethesda, TN is just 20 miles or so from where I live. :wink:
…I still gotta come down for that visit… :wink:
Better hurry. Only two more months of summer! :smiley:
