It looks a bit different to begin with, but then Eve got a hold of it and spent 30min having me change colors and gamma levels. Heh, women.
Oh and the GPS did indeed arrive today, quite early actually. Too bad I have a tremendous work load today, donāt think Iāll have any chance to play with it until at least tomorrow, probably Wednesday. But Iāll get a new video up once itās ready. Show off the text/picture messaging and GPS.
@ Architect - For $40 the GPS module is AMAZING. Last night I had an issue locking satellites, but prior to that Iāve seen it cold boot a lock in under 30 seconds, indoors. Which, the doc says it canāt do at all. Speed & Course seem a bit iffy, especially when standing still, but good enough. And the lock on, Iāve actually had it (when 7 sats are locked) get me close enough that I could sayā¦yup, thatās where my chair is in the living room. If you want a cheap, fast & decent GPS unit definitely check it out.
@ FireyFate - After I took the picture I updated it to grab date/time from the GPS and correct for timezone & DST. Changing the millennium would be a simple task, Iāll ask the little lady what she thinks.
It rocks, particularly if you keep it warm standby mode with a coin cell or board power. It uses something like 7 uA in standby, and only about 20-25 mA when turned on. This version even has a built-in logging feature. Iām working on a gadgeteer module using this GPS⦠some much needed competition for the Seed module.
Iām working on a custom wristmounted enclosure for the new Pipboy with Shape Lock and using the OLED instead of the 4.3". Iāll be using the Cerb40 to power it.
Yup, Iām using an extender (as soon as it gets here) to connect the OLED to the Cerb40. Everything should mount inside nicely, if a bit snug.
Iāve just added the back to it as well. I know itās not pretty but since all I had was 5hrs, some Shape Lock and my 2 hands, not too shabby I think.
I havenāt made video yet since I wanted to show the dot moving around the google map image, which is kinda hard to do while driving. But Iām taking a vacation with the family in a week and a half so maybe I can get Eve to video it while we drive.
Oh ShapeLock how I love and hate it. If you donāt need it to be pretty, ShapeLock can be pretty great. If left thin itās flexible if made thick itās nice and solid.
To illustrate that point to Eve last night I tossed her new enclosure at our ceramic tile floor repeatedly, it was no worse for wear.
But you see all those bumps and divots? Thatās with using a mold. Even with a nice mold you just arenāt going to get something nice and perfect smooth. But it is definitely good enough. We plan on covering that enclosure with leather at some point so itāll be solid and you wonāt notice the inconsistent surface.
Working with large areas is very tough too. I didnāt have a bowl big enough (didnāt want to use a boiling pot of water because I was working with so much I figured Iād end up leaving it on at some point and ruining the material) to fit all the Shape Lock I needed for even just the bottom so I ended up having to nuke bowl after bowl all while keeping a hair dryer on the current piece to keep it warm. Cold Shape Lock + Warm Shape Lock = NO BOND.
Though I am VERY happy with how the screw mounts worked out. Simply wrap some around a screw, slap it on and let it cool. Now remove the screw and youāve got a perfect thread.
And despite what everyone else says you CAN sand it. Just very carefully and slowly. I used a belt sander on the bottom to remove a full inch of material. It took an hour of sand, remove, peel off molten plastic, repeat. But it does work.
Depends on the shape and thickness. Mine wouldnāt have held up to planing well at all because of the shape. It would have kept rolling over and giving an uneven plane.
