We are glad to have completed the GHI OSH SDK. This is still a beta release but it is complete. It even includes RLPLite! The following is GHI package installer. In includes everything even GHI’s non-OSH SDK. It also includes the new Gadgeteer SDK
Updated Hydra firmware using jumper method. This took much longer than expected. I didn’t time it but I would guess 6-7 minutes. It did appear to be successful though according to the log.
Started a new Gadgeteer project. Woo! hoo! My USB modules appear in the Toolbox again!
F5 - deploy. No go.
Device not found or cannot be opened - USB:Gadgeteer========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
We will change the name to what gadgeteer template expects. For now, you need to change the settings back and forth to update the project to not use “gadgeteer” but use “hydra”
Now all it will do when I try to deploy is get to the stage “Preparing to deploy assemblies to the device.” and spin… 15 min now and still not deployed. I’ve restarted VS several times. Only thing left is to restart the computer. I guess I’ll do that and try again in the morning…
@ Gus - no worries; I gleaned as much from another post.
So far, the results are promising.
Didn’t you say that the flipped colors on the DaisyLink LED module was fixed in this release?
…Or am I misremembering …?
@ Jimmy I think they will not be really fixed until a new firmware is available for the LED module. Until then, you have to call the Flip…() functions.
I’m still dead in the water. I can’t get VS to deploy to Hydra since installing this update. It still just spins its wheels while trying to deploy. I’m getting the same result whether I’m deploying a native project or a Gadgeteer project. So, I think there’s either something wrong with VS as a result of the SDK update or there’s a problem with the firmware update. Is no one else having this problem or am I just lucky?
Any ideas? I’ll be home soon and would like to make some progress. Otherwise, I guess my next steps are to uninstall/reinstall everything and re-apply the firmware and hope something gets fixed.
I am not sure why this is happening to you. Has anyone else try this new SDK with hydra? It is workin fine here.
Do this, go to MFDeploy and change “USB name” to “Gadgeteer”. Then you will see “FEZHydra_Gadgeteer” on MFDeploy. Ping it and you will see TinyCLR back. Now, make new gadgeteer project and load it.
Reading from joystick completely haults everything.
And man do I ever want to rewite that displaymodule base class. I know it’s an MS thing but how do they put in 2 interfacing WPF and Sans and not even have line methods…ok rant mode off; I’ll just code an alernative.
In the mean time; email module code changes to normal GHI email or what?
