And, what are the prospects for using an MII/RMII PHY for Cerberus and Cerb40? Is there a memory advantage for going with the ENC28J60?
Ok gus
It means that this is the āmostā powerful non gadgeteer module GHI proposes if Iām correct ?
The only drawback is to have to wait till Q3 to use itā¦
Thereās still ChipworkX, which is a 200 MHz ARM9 with gobs of flash and RAM. This is a Cortex-M3, though, so the MHz numbers arenāt directly comparable.
Iād still probably give ChipworkX the edge, however.
only drawback of the chipworkX is the current priceā¦ quite expensive for hobby project
Indeed, it seems like the G120 hits a very sweet spot. Could this be the effective end of the EMX?
Or the beginning of an updated EMX? ā¦ you never know and I wonāt tell you
ā¦ just teasing
@ GUS - would you answer godefroi question. " Are you using the onboard ethernet MAC, or are you planning on using the ENC28J60?"
I hope its onboard.
P.S. this is all so very exciting!
I want one!!!
I like it because:
1.) Have Premium Library(WiFi, USB, PPP, IFU, RLPā¦)
2.) Faster,smaller, than EMX, but āsameā mounting "socket"
3.) Good operating temperature(-40Ā°C to 85Ā°C)
But I have questions:
1.) What about Piracy Protection? Is this part of Premiun Library?
2.) About LCD support will be still limited to video buffer size = 960000?
3.) What will be SD & Ethernet max speed?
Will be āengeniring moduleā avalible sooner than Q3 2012?
A faster EMX, with ethernet, great! I see no MCI interface, so SD card access will have to go over SPI.
EDIT: LPC178x seems to contain a dedicated MCI interface for SD/MMC card access, I was looking in the LPC17xx User Manual which did not mention the LPC177x and LPC178x variants.
Looks like youāre right.
I canāt fault GHI for going with the NXP chips, theyāre solid, and GHI has lots of experience working with them, but man, looking through the NXP datasheets reinforces (for me) just how feature-rich the STM32 is. The peripheral list is truly incredible!
@ Wouter, Maybe i am not so clear today, but the overview of the board says: 4-bit SD card interface as well as the LPC17xx datasheet says āSD/MMC memory card interfaceā
@ Robvan Schelven: you are right: I was looking in the general LPC17xx user manual, where they donāt seem to mention the LPC178x, from this document: http://ics.nxp.com/products/lpc1000/datasheet/lpc177x.lpc178x.pdf it idd looks like it will contain a dedicated SD/MMC controller. That is good news!
Wow, yep, itās right there. How did we miss that the first time around? :o
You should not miss any feature going from EMX to G120, you should get more but further details will come in near future.
Will the JTAG/SWD port be exposed?
@ GUS - Can you answer this question please
We will make sure you are happy at the need, leave it at that for now Sorry, I am not allowed to say more!
@ Gus- ok just so we are clear on my needs. Which are on board internal.
May we have Pin-Out details?
I am starting a board layout that I want to use an EMX or G120. My planās are to put both sets of pad down at the same location. Do you have any documentation that shows the G120 module pin-out and board dimensions?
I am also planning on using the Redpine WiFi module which I assume is compatible with both modules.
