I am downloading an application file over cellular, it takes about 6 minutes or so. The byte count at the end of the download matches the file size. An error gets thrown at updater.VerifyApplication().
static void DownloadFile()
var url = "http://myurl/myfile";
Debug.WriteLine("Start Download");
int read = 0, total = 0;
byte[] result = new byte[2048];
var qspiDrive = StorageController.FromName(SC20260.StorageController.QuadSpi);
var updater = new InFieldUpdate(qspiDrive);
try
updater.ResetChunks();
var appKey = new byte[] { 0x00, 0xMyKey, 0xbd };
updater.LoadApplicationKey(appKey);
using (var req = HttpWebRequest.Create(url) as HttpWebRequest)
req.KeepAlive = true;
using (var res = req.GetResponse() as HttpWebResponse)
var loops = 0;
using (var stream = res.GetResponseStream())
do
read = stream.Read(result, 0, result.Length);
updater.LoadApplicationChunk(result,0, result.Length);
total += read;
loops++;
if (loops >= 10)
Debug.WriteLine("total : " + total);
loops = 0;
while (read != 0);
Debug.WriteLine("Total : " + total);
Debug.WriteLine("Start Verify");
var firmwareVersion = updater.VerifyApplication();
Debug.WriteLine("Verify Done: " + firmwareVersion.ToString());
catch (Exception ex)
Debug.WriteLine("Download Error: " + ex.Message);
Is this a legit way to calculate MD5 while downloading?
var url = "http://my.url/myfile";
byte[] result = new byte[1024];
var md5 = MD5.Create();
byte[] md5Hash = new byte[16];
try
md5.Clear();
var appKey = new byte[] { 0x22, myappKey, 0xbd };
do
updater.LoadApplicationChunk(result, 0, read);
md5Hash = md5.ComputeHash(result, 0, read);
Array.Clear(result, 0, result.Length);
total += read;
}while (read != 0);
md5Hash = md5.Hash;
var Hash = "";
foreach(byte b in md5Hash)
Hash += b.ToString("x2");
Debug.WriteLine("Hash: " + Hash);
_DownLoadFile = false;
The Hash that I get is different than what I get from the file that is on the webserver. (webserver file and dev pc MD5 match.) However, I am not sure I am calculating it correctly.
The byte count matches between the server and the total I am receiving. If the data is getting corrupted on download then I am not sure where to go next.
Using a C# console app to calculate the MD5 and here are my results.
When doing the MD5.ComputeHash inline with the download I get the same I get on SitCore: MD5 done inline: d41d8cd98f00b204e9800998ecf8427e
In the console app, I save the file to disk and calculate the MD5: MD5 full file: 1a52799318f7b40d42412113b46bb51d
The full file hash matches the server and original .TCA file. So it appears that all the bytes are making it through the cellular download. But there is a difference between the inline compute and the full file compute. I would need to run the full hash on what gets saved to qspi flash. Is there a clever way to do that?
You should read them all, keep it memory (I see you use SC20260 with 32MB memory). Then do MD5 for all file one time. It is much more simple. Do same with PC.
Compare two values.
What we care about is the content of your download. You can download to SDCard and bring to PC to compare with orginal file.
You can make a program 1.8MB (add some rescources), extract TCA, and send project to us so we can run quickly. Make sure you can reproduce with that project first.
I also noticed that every 4K there was an “Erase Flash” message, that wasn’t there with random chunk sizes.
Test Code:
do
if (stream.Length >= 1024)
updaterSPI.LoadApplicationChunk(result, 0, read);
total += read;
} while (stream.Length > 0); // (read != 0);
md5Hash = md5.Hash;
var Hash = "";
foreach (byte b in md5Hash)
Debug.WriteLine("Start SPI Verify");
updaterSPI.LoadApplicationKey(appKey);
var firmwareVersion = updaterSPI.VerifyApplication();
Debug.WriteLine("Verify SPI Done: " + firmwareVersion.ToString());
Will the TCA files always be in 1K increments? The test code above doesn’t have a provision for less than 1K at the end. If the TCA file is always 1K increments then I won’t have to worry about it, or will I?
I am still calculating the MD5 hash as a test. The end result is that the MD5 hash calculated in line with the download doesn’t match the hash generated on the server or PC.
every time write the size need to be same. You can’t write 1K then next 2K. If decided 1K then all must be 1K. If decided 2K then all must be 2K, except for last block.
Tca is always multiply of 1K.
Second:
I don’t think do MD5 inline will work. As your log, I see every time reading data from network, the size is different, so MD5 will give different result of couse.
if tried 1K worked, then no worry, we know what your problem is. You can tried 2K, 4K for sure, but not 3K or 5K because sector size is 4K.
If tried 2K, 4K… then need to take care last block. Example tca 9K = 4 + 4 + 1. If do 4 +4 +4 then exception :)).
@Dat_Tran Thanks for the help. I hope I didn’t miss something in the docs that could have saved everyone’s time. If I did I apologize.
I will stick with 1K buffer size. I don’t have 32MB ram and with MQTT connected to Azure my RAM is a bit tight.
I don’t think MD5 is important since the IFU verify will fail if the file is corrupt.
When VerifyApplication() fails are there different exceptions indicate if it was due to a bad Application Key or corrupted file?
Now the hard part, creating the back end to support over-the-air updates on a fleet of devices.
