It is about a square inch! The size of US quarter! Why? @Justin keeps on bugging me about a tiny 100BGA SITCore chip for his watch but then if we are going to offer such chip, we have to also put it to other good uses. And then this idea was born! SC20100 with Ethernet PHY on a single super tiny module!
So, if you like what you see, thank @Justin for the constant nagging
These are not that hard to hand solder. I do this all the time with the older G400S and G120. I also do this with the ESP32 etc. The trick is to solder 2 corners and then run a bead of sticky flux along the connections and then use a larger tip with a blob of solder on it and drag it along. You can also do them one by with a smaller tip. Then clean with IPA. Works a treat.
I think you are being a typical Murican and overstating the size of your equipment
If my assumption of 1.27mm pitch is correct then that would make it 950 x 800mil so 0.76 sq.in
Just sayin…
