It tells me this: “If you are using a FEZ Spider and plan on using it in a Gadgeteer project, you must rename the USB name for Visual Studio to properly see the device for deployment. In MFDeploy, go to “Target->Configuration->USB Name”. Here, you must set the USB Friendly Name to Gadgeteer. Click Apply. If you are updating a FEZ Spider, at this point you should put the on-board switches back to “Default” mode.”
So does this mean it is currently not possible to change the USB name after upgrading the firmware to NETMF 4.3?
@ Brett - I am someone with a spider. I can confirm that it still works from VS2012 with the default USB device name (EMX_EMX). So the docs should be updated.
@ candritzky - I’ve added a brief comments to the emx firmware page regards FEZ Config automatically doing the rename step. Thanks for pointing out the omission.
@ Gus - hi ! I just received a card Fez panda-II, and I want to update the firmeware card to version 2, to do this I must have tool Fez-config but unfortunately I do not have on my computer even after you install the package GHIs-electronics and there I searched the net and I came across this discution gave me MFDeploy tool
I wonder as well, is that this tool can help me to update the firmeware card panda-2
@ Architect -
oh thanks…I just find it on the net, the tool is called USBizi-updater and not Fez-config
apparently, I met another trick: is it necessary to update the firmeware before using the card if i have firmeware version 4.1.8.0 according to USBizi-updater ?
cordially.
You should be good. It is in the release notes document, that is located in your installation folder.
Here it is:
• USBizi (FEZ Mini, FEZ Domino, FEZ Rhino, FEZ Panda) V 4.1.8.0
• EMX (FEZ Cobra) V 4.1.8.0, TinyBooter V 4.1.6.0
• ChipworkX V 4.1.8.0 TinyBooter V 4.1.5.1
• GHI NETMF Library V 4.1.8.0
