cypher
July 28, 2010, 6:33am
21
Robert,
Here is my output
[quote]HalSystemInfo.halVersion: 4.1.2821.0
HalSystemInfo.halVendorInfo: Microsoft Copyright © Microsoft Corporation. All rig
HalSystemInfo.oemCode: 255
HalSystemInfo.modelCode: 0
HalSystemInfo.skuCode: 65535
HalSystemInfo.moduleSerialNumber: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
HalSystemInfo.systemSerialNumber: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
ClrInfo.clrVersion: 4.1.2821.0
ClrInfo.clrVendorInfo: Microsoft Copyright © Microsoft Corporation. All rig
ClrInfo.targetFrameworkVersion: 4.1.2821.0
SolutionReleaseInfo.solutionVersion: 4.1.0.0
SolutionReleaseInfo.solutionVendorInfo: GHI Electronics, LLC
SoftwareVersion.BuildDate: Jul 23 2010
SoftwareVersion.CompilerVersion: 310739
FloatingPoint: True
SourceLevelDebugging: True
ThreadCreateEx: True
LCD.Width: 320
LCD.Height: 240
LCD.BitsPerPixel: 16
AppDomains: True
ExceptionFilters: True
IncrementalDeployment: True
SoftReboot: True
Profiling: False
ProfilingAllocations: False
ProfilingCalls: False
IsUnknown: False
[/quote]
What is shown on the display? My Cobra shows version 4.1.0.0
Maybe the firmware is not completely removed with Tinybooter. Could retry to delete it via Tinybooter?
Strange, mine sais 4.0.4.0 ???
[quote]HalSystemInfo.halVersion: 4.0.1681.0
HalSystemInfo.halVendorInfo: Microsoft Copyright (C) Microsoft Corporation. All rig
ClrInfo.clrVersion: 4.0.1681.0
ClrInfo.clrVendorInfo: Microsoft Copyright (C) Microsoft Corporation. All rig
ClrInfo.targetFrameworkVersion: 4.0.1681.0
SolutionReleaseInfo.solutionVersion: 4.0.4.0
SoftwareVersion.BuildDate: Jun 30 2010
FloatingPoint: True
LCD.Width: 320
LCD.Height: 240
AppDomains: True
SoftReboot: True
Profiling: False
IsUnknown: False[/quote]
Strange, this is also wrong.
Using terraterm, I have deleted and deployed everything 3 times now.
I have downloaded the SDK 4.1 beta from GHI (even did the things in readme)
Why am I still having the old firmware? ???
cypher
July 28, 2010, 8:53am
23
I don’t know :
Is there a command in Tinybooter where you can check that the firmware is completely removed?
How long does it take to delete the firmware? I use the video from Gus. It take some time (you see it in the video)
Did you check the release notes to make sure you have the right firmware like the video shows?
Yes, I did:
[quote]Version Info
Firmware, Tinybooter (if applicable) and libraries are compatible for each SDK release and they may not work with previous releases. Make sure to update all your software components including firmware and library assemblies. Otherwise, your managed application will not run at all or run incorrectly.
Important note: Requires .NET Micro Framework 4.1 and Visual Studio 2010
• USBizi (FEZ Mini, FEZ Domino, FEZ Rhino) V 4.1.0.0
• EMX (FEZ Cobra) V 4.1.0.0, TinyBooter V 4.1.0.0
• ChipworkX V 4.1.0.0 TinyBooter V 4.1.0.0
• GHI NETMF Library V 4.1.0.0[/quote]
That is impossible! If this is what is in your SDK and you updated the firmware then your firmware should be 4.1.0.0 :wall:
cypher
July 28, 2010, 10:06am
27
He he he,
yes you should hover with the mouse cursor over the GHI NETMF SDK.msi file and check that the title shows GHI NETMF v4.1 SDK :whistle:
As you can see, it is. I will try again after diner… :wall:
Ok this is strange… ??? now it worked? ???
Hmm the display sais 4.1.0.0 and the device capabilities too…
Strange… :think:
woooooooooooooooo cobra is alive again :dance:
And the deployment succeeded with just 1 try! Also, the assembly “error” is fixed!
GOOD GOOD work crew!
cypher
July 28, 2010, 12:01pm
31
Or is it your daily joke , like Josh is doing with the website :dance:
He he he he
[quote]Or is it your daily joke , like Josh is doing with the website
He he he he[/quote]
Haha yes just wanted to freak you guys out
Nah, I really do not know how this happened… Anyway: it works, and the annoying errors are flawlessly fixed, and I am very happy about that. :dance:
anyone know when the mini 4.1 sdk will appear on the downloads page? approximatly?
Woohoo! Been playing with the emulator a bit with 4.1, looks pretty sweet
cool something to play with over the weekend, (apart from golf of course)
Where is it guys? I’m really impatient, thanks for your work anyway.
We found a little problem in our one-wire library and so we will not release it till this is fixed. This may delay till Monday but I hope not
You do not need the 4.1 SDK to use FEZ. You can use it now already with 4.0…but will be nice to have the latest and greatest
