Hello guys,
I am facing troubles with G400S - with flashing new bootloader.
it seems to me that dataflash does not work. But I need confirmation, than i will try to change it on module.
first 30 pcs was assebled and work properly almost 2 years. Now factory assembled for us second series of our device. and when i would like to flash new samba bootloader, so the module does not answer at flashing …
But if i am trying get answer from DDR - so it works…
with older serie it works properly.
( it’s on our board, vcc corect, connected only with USB, windows can see the port, i can communicate via samba v2.12 )
Hi Gus,
thanks for fast response. Of course i could see user guide.
in log file above you can see, that i am able to connect but answer to “execute” data flash enable is with error.
answer to command “execute” ddr ram is with succes.
if the older module ( correct one) is connected i can get succes to dataflash enable and i can download bin file…
if i am not able to communicate with dataflash ( in newer module) so there is no chance save the bootloader .
Hi Dat,
Thanks. I tried. still the same response. ddram execute valid answer. execute enable dataflash
( error initiali… ) / win7 prof. usb2 port. samba 2.18.
if i am tring older module with the same sw and hw platform so it still works properly via all steps…
Hy Gus,
We tryied it. my colegue notebook with win10. Me personally notebook win7 prof / and second standard PC with win7 prof. All 3 stations with the same result. Answer to execute DDR ok, answer to initialize dataflash with error message.
J.
What does it say in your device manager for the connected device? Remember you need to short out a pin (I cant remember which)… so that it changes to a Bossa device (or something like that)
So our schematic was under revision of Gus Issa. I got advice to switch off all peripherals connected to SPI ( we have on our board buffer atd eth phy), all has to be inactive, because SPI shares bus with dataflash on G400.
When the bus is clear so samba’s and tinyboot’s update work correctly regarding user guide.
Thanks a lot
Jindrich
