We have about a dozen of USBizi-DevSys boards that we want to give away for free. This is a discontinued product that was replaced by the FEZ boards but the chipset/firmware used on the board is USBizi…in other words, this is 100% FEZ Domino or FEZ Rhino! See image below.
We have tested them and loaded them with latest firmware with a blinking LED example (LED is on USBizi pin #2)
If you are a user level “FEZ Junior” or higher and you have use for this free board then please send an email to ghielec@ ghielectronics.com with your forum user name and a link to this post.
Quantities are limited
No support is provided and this is why we are offering these to experienced users only: You still need these docs:
Meh, FEZBomb has been on the chat and I have seen plenty of good posts from him. He’s got my recommendation… Maybe it’ll help with his self navigating boat
Lets put it this way, if you are less than FEZ Junior and want one of those then still send an email with details on your FEZ experience (no support is provided to these boards) and tell us how you want to use this board.
We will try to do our best but can’t promise since higher ranks get higher priority
Oh well. I snoozed so I lose Thanks for the reply. BTW I really like the FEZ products. I do C# programming as a profession so I find the FEZ’s easy to work with.
Gus, will it ever be considered to put devSys to production (market)?
I really would like a board where is nothing that you dont need, and has everything to simply start and go. I even like layout of devSys, it will perfect fit in almost all my robotic applications.
I don’t like mini for its fancy connections. I don’t like domino cause it feels like i’m waisting those precious pins. The rhino is overcrouded (wiznet connection). And the cobra is too big for me.
Tho I like my panda very much.
I know those boards are only for startig, and I can make myself a board out of USBizi, but it’s easier to buy one from You.
EMX module just can’t egzist on its own You still need to solder it to some board.
My point is, as a robotic hobyist I would like to see board with through hole connectors and bare minimum electronics. Like all sparkfun production. Just controller, crystal, USB, and maybe sd card. Panda meets this requirments but has 2 minuses - arduino layout (I still didn’t get how it become so popular) and no USB host support.
devSys is nearly perfect (I would like third line of IO pins near those 20pin lines), but I’ve never see that board before this thread.
I hope GHI has plans for that kind of board in a future (cross fingers).
