Not sure if this will help or not, but I found that if I uninstall the Unknown Device driver, then click “Scan for Hardware changes” in the Device manager.
It quickly flickers like this: (see attached image)
Before returning to the same as the picture above.
[quote]It quickly flickers like this: (see attached image)
Before returning to the same as the picture above.[/quote]
That bit - the flicker - is normal. It’s the step between when Windows knows “something” is there and when it knows what’s really there and to do with it…
After the initial firmware update, did you reset the switches on the Spider?
I can’t. When I try to do so it gives me the error message:
Cannot connect to the device! Follow steps 1 to 2.
See above, I can’t even get by the initial firmware update.
Also, I have tried loading it in default and loader mode. Neither are picked up on the computer.
At this stage, I have done 2 system restores and even tried going through safe mode with driver signature verification disabled!
Nothing has worked…
I guess the problem must be something on the hardware side. I’ll try it with a different USB cable tomorrow. Can’t find a spare one here at the moment.
