Hi
I have a question about timers and their availability, please fix me if I’m wrong:
- Signal Control
- SC20260.Timer.DigitalSignal.Controller2.PB3 - can be used? (PA15 from PWM Controller2 is used by display - does it use timer?)
- SC20260.Timer.DigitalSignal.Controller5.PA0 - loosk like free (co other pin corresponded from PWM Controller 5 is used)
- PWM
- SC20260.Timer.Pwm.Controller1.PJ9 - is it free? PK1 from this group is used by display
- SC20260.Timer.Pwm.Controller3.PC7 - free (no other pin from group use PWM)
- SC20260.Timer.Pwm.Controller8.PI2 - free (no other pin from group use PWM - PB1 connected to buzzer but I will not use it)
- SC20260.Timer.Pwm.Controller12.PH9 - free (no other pin from group use PWM)
- SC20260.Timer.Pwm.Controller13.PF8 - free (no other pin from group use PWM)
- SC20260.Timer.Pwm.Controller14.PF9 - free (no other pin from group use PWM)
- SC20260.Timer.Pwm.Controller15.PE6 - free (no other pin from group use PWM)
I nead 2 Signal Control pins (read + write) and 6 PWM (independent and used in the same time).
Thanks for help.
BR
KJ
