Our Fast & Easy (FEZ) product line has been helping professionals, educators and tinkerers for the past 3 years. We mainly used .NET Micro Framework to allow users to program the devices in C# and VisualBasic. The hardware was also standardized to the open .NET Gadgeteer specifications. With the ever expanding list of modules that can be plugged into our FEZ family products, we are working on expanding the mainboard to include some lower cost options and some high end options. All these options are grouped under Gadgeteering on our online catalog. The Gadgeteering category branches into three platforms, Arduino-Compatible, .NET Gadgeteer and Linux-Mac-Win. All those platforms work with the modules listed under Gadgeteering and we even include laser-cutting service and other hardware to help you build a professional looking product.
Introducing the Arduino-compatible FEZ Medusa!
Going live today, on the crowd funding KickStarter website, is our all new Arduino-compatible FEZ Medusa, starting at only $10. Just like before, this product is Fast & Easy to work with. It is compatible with our modular hardware, which also ships with the complete software driver and libraries for a true plug and play platform.
Being Arduino-compatible, allows FEZ Medusa to be easily programmed using the Arduino IDE, which runs on Windows, Linux and Mac. A user will only need to plug in the needed modules to the compatible sockets and then include that modules driver in the IDE and the module is ready to be used. No datasheets to open, no schematics to read. But what about advanced users who are interested in tweaking and modifying the hardware or the software? Since FEZ Medusa is open source, where the hardware and the software are provided free of charge, even for commercial use, advanced users can still dig into the drivers sources and read the schematics to tweak or completely modify the software and hardware to fit their needs.
FEZ Medusa comes in three flavors, ranging from the $10 FEZ Medusa Mini to the socket-loaded FEZ Medusa S12 and FEZ Medusa Shield.
Plug and play sensors for Raspberry Pi, BeagleBone, laptops, tablets and phones!
We did not stop at expanding on the lower-end, we also expanded on the higher-end, where users require 1Ghz or more of processing power. The all new FEZ Lynx is a gadgeteering mainboard that works with the same plug and play modules. Using a USB cable, FEZ Lynx accepts commands over USB to access the connected modules. The same software developed for FEZ Medusa will also run on the system that will command FEZ Lynx, like a Raspberry Pi. An example may be a laptop that is mounted on a robot, which uses Microsoft Kinect for object detection and then the same laptop uses FEZ Lynx to command the Motor Control Module to move the robot, and command the relay module to control some lights.
FEZ Lynx is a stretch goal to the FEZ Medusa campaign. Please visit KickStarter to learn more about FEZ Medusa and FEZ Lynx.
KickStarter : http://www.kickstarter.com/projects/1359959821/an-arduino-compatible-electronic-building-block-sy
Gadgeteering : https://www.ghielectronics.com/catalog/category/517
Arduino-Compatible : https://www.ghielectronics.com/catalog/category/516
Linux-Mac-Win : https://www.ghielectronics.com/catalog/category/526
