Hello All,
My end goal here is to talk via MQTT between a FEZ Portal and FEZ Feather. I’m still working on establishing a WIFI connection between the two and having a bit of trouble.
On the Feather, I have created a WIFI Access Point “StableSwitch Net”. I’m able to see the WIFI network from my phone and establish a connection.
However, when I try to create a client connection from the Portal I get an Exception thrown when I try to enable the client network controller.
Enable the network controller.
#### Exception System.ArgumentException - 0xfd000000 (1) ####
#### Message:
#### GHIElectronics.TinyCLR.Devices.Network.Provider.NetworkControllerApiWrapper::Enable [IP: 0000] ####
#### GHIElectronics.TinyCLR.Devices.Network.NetworkController::Enable [IP: 0007] ####
#### StableCamper_Switcher_UI.MainWindow::.ctor [IP: 0043] ####
#### StableCamper_Switcher_UI.Program::Main [IP: 001b] ####
Exception thrown: 'System.ArgumentException' in GHIElectronics.TinyCLR.Devices.Network.dll
I am able to connect the client on the Portal to my local WIFI network and reach the outside world with a ping.
I’m guessing that the issue with my Access Point on the Feather since the Portal client is able to work with the local WIFI network.
FEZ Feather Access Point code:
public static GpioPin led;
static void Main()
led = GpioController.GetDefault().OpenPin(SC20260.GpioPin.PE11);
led.SetDriveMode(GpioPinDriveMode.Output);
InitializeWifi();
public static void InitializeWifi()
var networkController = NetworkController.FromName(SC20100.NetworkController.ATWinc15x0);
//Setup Pins
var enablePinNumber = FEZBit.GpioPin.WiFiEnable;
var chipSelectPinNumber = FEZBit.GpioPin.WiFiChipselect;
var irqPinNumber = FEZBit.GpioPin.WiFiInterrupt;
var resetPinNumber = FEZBit.GpioPin.WiFiReset;
var spiControllerName = FEZBit.SpiBus.WiFi;
var gpio = GpioController.GetDefault();
var enablePin = gpio.OpenPin(enablePinNumber);
enablePin.SetDriveMode(GpioPinDriveMode.Output);
enablePin.Write(GpioPinValue.High);
SpiNetworkCommunicationInterfaceSettings networkCommunicationInterfaceSettings = new SpiNetworkCommunicationInterfaceSettings();
var settings = new SpiConnectionSettings()
ChipSelectLine = gpio.OpenPin(chipSelectPinNumber),
ClockFrequency = 4000000,
Mode = SpiMode.Mode0,
ChipSelectType = SpiChipSelectType.Gpio,
ChipSelectHoldTime = TimeSpan.FromTicks(10),
ChipSelectSetupTime = TimeSpan.FromTicks(10)
networkCommunicationInterfaceSettings.SpiApiName = spiControllerName;
networkCommunicationInterfaceSettings.GpioApiName = SC20260.GpioPin.Id;
networkCommunicationInterfaceSettings.SpiSettings = settings;
networkCommunicationInterfaceSettings.InterruptPin = gpio.OpenPin(irqPinNumber);
networkCommunicationInterfaceSettings.InterruptEdge = GpioPinEdge.FallingEdge;
networkCommunicationInterfaceSettings.InterruptDriveMode = GpioPinDriveMode.InputPullUp;
networkCommunicationInterfaceSettings.ResetPin = gpio.OpenPin(resetPinNumber);
networkCommunicationInterfaceSettings.ResetActiveState = GpioPinValue.Low;
networkController.SetCommunicationInterfaceSettings(networkCommunicationInterfaceSettings);
WiFiNetworkInterfaceSettings networkInterfaceSetting = new WiFiNetworkInterfaceSettings()
Ssid = "StableSwitch Net",
Password = "0123456789",
Mode = WiFiMode.AccessPoint,
Channel = 6
networkInterfaceSetting.Address = new IPAddress(new byte[] { 192, 168, 0, 201 });
networkInterfaceSetting.SubnetMask = new IPAddress(new byte[] { 255, 255, 255, 0 });
networkInterfaceSetting.GatewayAddress = new IPAddress(new byte[] { 192, 168, 0, 1 });
networkInterfaceSetting.DnsAddresses = new IPAddress[] { new IPAddress(new byte[] { 75, 75, 75, 75 }), new IPAddress(new byte[] { 75, 75, 75, 76 }) };
networkInterfaceSetting.DhcpEnable = true;
networkInterfaceSetting.DynamicDnsEnable = true;
networkController.SetInterfaceSettings(networkInterfaceSetting);
networkController.SetAsDefaultController();
networkInterfaceSetting.AccessPointClientConnectionChanged += NetworkInterfaceSetting_AccessPointClientConnectionChanged;
networkController.NetworkAddressChanged += NetController_NetworkAddressChanged;
networkController.NetworkLinkConnectedChanged += NetController_NetworkLinkConnectedChanged;
networkController.Enable();
Thread.Sleep(-1);
//on connection
private static void NetController_NetworkLinkConnectedChanged(NetworkController sender, NetworkLinkConnectedChangedEventArgs e)
//throw new NotImplementedException();
Debug.WriteLine("EVENT: NetController_NetworkLinkConnectedChanged");
Debug.WriteLine(e.Connected.ToString ());
led.Write(e.Connected? GpioPinValue.High: GpioPinValue.Low);
//on disconect
private static void NetController_NetworkAddressChanged(NetworkController sender, NetworkAddressChangedEventArgs e)
Debug.WriteLine("EVENT: NetController_NetworkAddressChange");
Debug.WriteLine(e.ToString());
// led.Write(GpioPinValue.Low);
//on connection
private static void NetworkInterfaceSetting_AccessPointClientConnectionChanged(NetworkController sender, IPAddress clientAddress, string macAddress)
Debug.WriteLine("EVENT: NetworkInterfaceSetting_AccessPointClientConnectionChanged");
Debug.WriteLine(clientAddress.ToString());
// led.Write(GpioPinValue.High);
FEZ Portal Station Code:
static void wifiConnectClient()
var enablePinNumber = SC20260.GpioPin.PA8;
var chipSelectPinNumber = SC20260.GpioPin.PA6;
var irqPinNumber = SC20260.GpioPin.PF10;
var resetPinNumber = SC20260.GpioPin.PC3;
var spiControllerName = SC20260.SpiBus.Spi3;
var gpioControllerName = SC20260.GpioPin.Id;
networkCommunicationInterfaceSettings.GpioApiName = gpioControllerName;
string[] ssidList = Winc15x0Interface.Scan();
foreach (var s in ssidList)
Debug.WriteLine(s);
WiFiNetworkInterfaceSettings networkSettings = new WiFiNetworkInterfaceSettings();
networkSettings.Ssid = "StableSwitch Net";
networkSettings.Password = "0123456789";
networkSettings.Mode = WiFiMode.Station;
networkSettings.Channel = 6;
networkSettings.DhcpEnable = true;
networkSettings.DynamicDnsEnable = true;
networkController.SetInterfaceSettings(networkSettings);
//this is where the exception is thrown....
Debug.WriteLine("Enable the network controller.");
try
catch (Exception e) {
Debug.WriteLine("Network controller is enabled.");
networkController.NetworkAddressChanged += NetworkController_NetworkAddressChanged;
//just a pause for test in debug
Thread.Sleep(100);
IPHostEntry ip = Dns.GetHostEntry("GHIElectronics.com");
Debug.WriteLine("GHI Electronics' IP = " + ip.AddressList[0].ToString());
private static void NetworkController_NetworkAddressChanged(NetworkController sender, NetworkAddressChangedEventArgs e)
var ipProperties = sender.GetIPProperties();
Debug.WriteLine("IP: " + ipProperties.Address);
var address = ipProperties.Address.GetAddressBytes();
Any help would be so greatly appreciated!
