Does USB Client support Mass Storage Class (MSC)?
I am porting some projects from the G400D (NetMF43) to the SCM20260D (TinyCLR) SOM.
The NETMF supports the Mass Storage Class (MSC) in USB Client mode, so when connecting a PC to the Deployment USB port (with the MODE switch set), the pc can access the SD-card acting as an USB-pendrive (see USB Client).
I am wondering if it is possible to do the same with TinyCLR, as I didn’t find any example in the USB Client tutorials (USB Client).
Thank you in advance for your help!
Regards
Vittorio
looks like its the same question as answered here TinyCLR Mount to PC as Mass Storage Device ?
Thank you so much!
I searched the forum prior to open this topic but I didn’t find it.
That’s exactly what I was looking for and unfortunately what I need it is not yet available.
Cheers
Vittorio
This feature is on the “to do” list. It might be a good idea to get in touch with us directly to make sure our timeline is aligned with what you need. We prioritize the work based on customer demand.
Hi Gus,
I will contact you directly, thank you.
Best,
Vittorio
It is available for next release now.
