If DHCP is static, I get a DNS error when I try the HHTP Client
https://docs.ghielectronics.com/software/tinyclr/tutorials/http-https.html
I have set DNS to “75, 75, 75, 75”
But if I make DHCP dynamic everything work, but I need static IP
Did you set the gateway address?
You need to set DNS to static as well, if you need static IP.
The current firmware doesn’t support Static IP but dynamic DNS, I believe we have that issue in github
