I think there is a bug somewhere with the cerb and the motion sensor.
Once the motion sensor has been triggered the motion sensed event fires every six seconds or so regardless of any movement.
Tested against a spider and it works fine on the spider.
Checked 4.2 QFE1 and now QFE2
I will give it a go, but I am interested as to why on the Cerberus the event continually fires once the initial trigger is fired (I even hid it in a cardboard box ) but doesn’t when on the spider.
Another question, does PIR have like a cooldown time, because it doesn’t react right after it changed back to inactive??
It does…10 seconds straight, not good for my project…
Last week we have test the motion module in Spider board with netmf 4.1 project, and does not work properly. The detection event is fired every once that finish the seconds set with the potenciometer.
Provably have some matter when set the input interrupt mode or resistor…
this.m_motionDetect = new GTI.InterruptInput(socket, GT.Socket.Pin.Three, GTI.GlitchFilterMode.On, GTI.ResistorMode.PullUp, GTI.InterruptMode.RisingAndFallingEdge, this);
Also I have test in cerberus board and works fine!
I try to find the problem… and post if found
Regards,
Since this thread is primarily concerned with an issue with Cerberus and motion detector, you should probably start a new thread for your issue, since it deals with Spider, not Cerberus.
Briefly, yes. Very early in my tenure at Microsoft. He was the DE for NYC. I’d only been on the team for around 8 months when he moved on, so didn’t get a chance to know him very well.
Cool, he and I now work together. I’ve just spent a week in amsterdam working with him. We got round to talking about gadgeteer and I mentioned your name and the conversation got round to previous work and he mentioned that he had previously worked for MS and he wondered if you were the same Andrew.
He told me to say hi
Ok Getting back on thread.
The motion sensor requires an X socket but in the designer i can connect it to Y sockets. Now the Cerberus only has Y sockets. Is this why the motion detector just keeps firing the motion sensed event on cerberus? I thought that the designer wouldnt let you connect to a socket if the module didnt support that socket?
Thanks Steven, can you think of any reason why the motion sensor just sits there triggering the interupt even if there is no movement on the cerberus?? is it something to do with the pull up mode in the driver?? As i said it works perfectly on the spider.
@ Justin heheh cheers chief, i did think that was the case too but just wanted to confirm i wasnt totally off my head
