No apologies, please! Your effort is very much appreciated. KiCad appeals to DIYers because it’s an OSS project. Laen is in a good place to monitor the shift in tool use.
Looks like there is an Eagle to KiCad ULP. Anyone know of a script that goes the other way?
Of course I disagree ! 8)
No, I’m kidding, don’t worry. Though I have to admit that I prefer the shield form factor.
The pin header spacing is not a problem anymore since we can find many existing layouts to start with.
The relative small size of such design also helps keeping the overall thing small, I think. Also, boards like Liquidware ExtenderShields may help in getting a good-looking design if more than one shield is needed.
A board like the Panda II is extremely versatile in this regard, I think, because it combines the best of both worlds : Arduino compatible pins for shields and custom pins for extended features.
In fact, when I read that Gus’ wife has seen a board that “looked like Arduino”, I immediately thought at a Panda II on steroids. Hence my deception when I saw the Cerberus.
But while I was crying silently in the dark, GHI suddenly offered the Cerb40 board, with a DIP40 pinout This will lead me to make “shields” (boards in fact) like Panda II with another processor, in fact.
And here, no Arduino form factor anymore Freedom design !
I think shields are great as long as you can limit your project to one shield and you’re careful to bring all your buttons on top… Beyond one shield and I much prefer Gadgeteer. Although I’ll probably only buy buy Gadgeteer & Cerb40’s in the future, today I’m working on a new Panda project that will have a single shield…
You will end up like this, Gus… But I would still be happy, despite your forced silence :-[
Cerb40 would fit my needs at the moment (once its firmware gets done, though) but if there’s “the same” processor on a Panda II design or like, then I would definitely take one or two !
Gus, I’m going to assume you can say absolutely nothing, but if you can, is it safe to assume that there will be a Cerberus derivative with onboard MicroSD, and (crosses fingers) integrated ENC28J60 ethernet? Maybe even USB host and device?
OK, so now, having looked at the Cerberus schematic, there are only two sockets that could be brought out completely, socket 2 and socket 6. Others are missing at least one signal, which may or may not be an issue.
The boards, produced by DorkbotPDX, run about $10 (unpopulated) as currently designed. Is it worth spending extra space on incomplete sockets?
nope, but remember i’m in the anti-socket crowd for this board. i’m also in the crowd that would prefer one continuous line of headers on each side… BUT… that’s the beauty of the small run fab services. we can each try our own variations on a theme.
can we get a peek at the final board layout, or is it the same as the one you already posted?
busy with eagle and kicad lately, eh? is the kicad UI more intuitive to use?
There are things about each I like. I like in KiCad the ability to move traces without changing any slopes, and I like that traces are labelled. In the end, though, Eagle wins out (for me), but KiCad is making pretty rapid progress.
It changed a bit, but not in any very interesting ways. I’m a little worried about the ZIF socket fitting, and SparkFun doesn’t have a datasheet for the one they carry :o
Not every pin on the MCU is brought out to the headers (there’s only four of them, after all). Pins in ( ) are missing:
