I’m having trouble updating the FEZ Spider Mainboard and keep getting the error: “the USB driver may not have installed correctly. Re-installing the USB driver may solve the problem”
I’ve re-installed absolutely everything, including the drivers and still get this error. Visual Studio Express also doesn’t “see” the Spider.
Furthermore, I’ve also tried using an external power and not just the USB cable.
Any ideas?
I’m running Windows XP (32bit) and installed the latest versions of all the required software.
Thanks Mike: The error occurs during the “reboot” phase (after erasing and writing). No change occurs to the device manager even though the updater claims to “disconnect” the COM port.
Thanks Andre.Marchalek: I don’t get any errors in the device manager in either normal or loader mode. The GHI Boot Loader Interface is there during both modes.
It is a physical XP machine.
Exit the updater. Restore the dips to the normal position. Remove power from device. Wait 5 seconds, and plug it in. What happens, and what does the device manager say now?
I believe if the first phase of the updater (erase/write) worked, but then failed, and the switches are in the default position, the Boot loader interface should not be appearing.
Having only the bootloader interface show up is good - it just means it has the bootloader on there and you can continue although may require more effort than usual
I can get as far as running TeraTerm (without any problems) and uploading TinyBooter. However I get this:[em]
File Transfer Finished Successfully
BL[/em]
I understand that I shouldn’t be getting “BL” again. Any ideas?
