@ Valkyrie-MT
Just for a sanity check here is what I’ve done.
G400HDR on socket 6
i have the Adafruit shield connected as follows
extender             cc3000
pin 1 (3.3v)       > not connected
pin 2 (5v)          > VIN
pin 3 (Int)          > IRQ
pin 4                 > not connected
pin 5 (enable)   > VBEN
pin 6 (CS)         > CS
pin 7 (MOSI)     > MOSI
pin 8 (MISO)     > MISO
pin 9 (SCK)   >100ohn resister  > CLK
pin 10 (GND)    > GND
also i added in the WifiAdapter
wifi = new CC3000Driver((Cpu.Pin) 95, (Cpu.Pin) 86, (Cpu.Pin) 6, SPI.SPI_module.SPI2);
i am getting the following program output
Found debugger!
Create TS.
Loading start at 202ce930, end 202fd8f8
Assembly: mscorlib (4.2.0.0)     Assembly: Microsoft.SPOT.Native (4.2.0.0)     Assembly: Microsoft.SPOT.Security.PKCS11 (4.2
.0.0)     Assembly: System.Security (4.2.0.0)     Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
Assembly: Microsoft.SPOT.Graphics (4.2.0.0)     Assembly: Microsoft.SPOT.TinyCore (4.2.0.0)
Assembly: Microsoft.SPOT.IO (4.2.0.0)     Assembly: System.IO (4.2.0.0)     Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0)     Assembly: Microsoft.SPOT.Touch (4.2.0.0)
Assembly: Microsoft.SPOT.Ink (4.2.0.0)     Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1)
Attaching deployed file.
Assembly: WifiExampleApp (1.0.0.0)  Attaching deployed file.
Assembly: Networking.WifiAdapter (1.0.0.0)  Attaching deployed file.
Assembly: GHI.Hardware.G400 (4.2.11.0)  Resolving.
Ready.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\mscorlib.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Native.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Security.PKCS11.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Graphics.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.TinyCore.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Touch.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Ink.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Users\a0psgzz\Desktop\CC3000WifiPatchProgrammer\ManagedCC3000Wifi\WifiCC3000\bin\Debug\le\Networking.WifiAdapter.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Users\a0psgzz\Desktop\CC3000WifiPatchProgrammer\ManagedCC3000Wifi\WifiExampleApp\bin\Debug\le\WifiExampleApp.exe’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI Premium NETMF v4.2 SDK\Assemblies\le\GHI.Hardware.G400.dll’
CC3000 Internet Time Example
Interrupt state before start: True
Starting up CC3000…
Sending - Simple Link Start
Shutting down CC3000…
#### Exception System.Exception - 0x00000000 (4) ####
#### Message: SPI response to Simple Link Start was invalid, check SPI connection to CC3000.
#### Networking.CC3000Driver::Send [IP: 0204] ####
#### Networking.CC3000Driver::Send [IP: 000b] ####
#### Networking.CC3000Driver::Init [IP: 002a] ####
A first chance exception of type ‘System.Exception’ occurred in Networking.WifiAdapter.dll
#### Exception System.Exception - 0x00000000 (1) ####
#### Message: Failed to initialize the CC3000.  Startup aborted!
#### Networking.CC3000Driver::Start [IP: 0043] ####
#### Networking.WifiAdapter::.ctor [IP: 00e0] ####
#### WifiExampleApp.InternetTimeExample::Main [IP: 000f] ####
An unhandled exception of type ‘System.Exception’ occurred in Networking.WifiAdapter.dll
Additional information: Failed to initialize the CC3000.  Startup aborted!
Uncaught exception
Done.
attached is the output from the logic analyzer
