@ mhectorgato - Wait, what did you buy? The Adafruit board? Yeah, I didn’t try the onboard 5V from the CerbuinoBee. This chip uses a lot of power, so I didn’t even think to power it from the CerbuinoBee. I know my external regulator got quite hot from trying to power the thing. There’s a decent chance that the CerbuinoBee can power it though… maybe someone should look at the specs though…
Oh, and when you get your module, let me know whether you got the old or new chip.
[quote]If you want to use a CC3000 WiFi module with your Netduino (or any other microcontroller running the .NET Micro Framework), you may be interested in the CC3000 Managed Driver for .NET Micro Framework.
[quote]This is a C# managed driver for the CC3000 Wifi adapter.
CC3000 Managed Driver for .NET MicroFramework is a 100% managed Wrapper for the SPI commands necessary to control the Texas Instruments CC3000 Wifi adapter
The purpose of this driver is to empower the C# developer to debug and add advanced networking features without having to change the firmware or learn C++ (similar to that of mIP). Since this is targeted to embedded devices, this library strives to use a minimal memory footprint. Also, the classes and methods MUST be simple and obvious to use and the critical public methods will be commented properly to allow for proper intellisense.[/quote]
There is already a working webserver and Internet time demo, so check out the project on Codeplex.[/quote]
[quote=“Valkyrie-MT”]
@ Gus. Porting the firmware patch code is probably non-trivial but do-able. [/quote]
Good news. It was definitely do-able. I have successfully written my own C# managed firmware patcher for the cc3000. No TI boards necessary. And, since the patch is passed as a byte array, it could easily be done over the air as long as you have the RAM or Flash to store the patch. I have not published it yet to codeplex because I want to limit availability until a few others report that it works. I have upgraded 4 or 5 cc3000 devices and bricked 1. The bricked one was the first try and I wrote a new File allocation table with an offset that was off by 2 bytes. I have since found that the FAT re-writing is not necessary, so the current version is much safer.
I’ve got the newer one (FCC markings) - iirc, it doesn’t need a FW update. If it does need one, I’ll try it out - because the likelihood of me getting a TI board for this is next to nil.
@ Valkyrie-MT
i got 2 boards that need the update. one from adafruit and 1 from GHI. I’m willing to test the firmware update code and test out the wifi code also.
I also have a logic analyzer that can capture spi.
I don’t want 10 people to brick their devices if there is a problem, so we’re gonna do this one at a time. I have someone testing the firmware patcher now. Once I get a thumbs up, I’ll give it to someone else… If we don’t have anyone brick it, I’ll publish it for everyone.
