Originally published at: AWS Home Surveillance – GHI Electronics
Today’s Spotlight is on a project by @RoSchmi who built a project showing Amazon Web Services (AWS) through TinyCLR OS on the SITCore development board.
The project has 2 end, the security system, which is GHI Electronics SITCore that is codded in C#, thanks to TinyCLR OS. The other end is the monitoring system, which runs on the PC to help in testing the data AWS is receiving. This can be replaced with a service that simply runs on AWS.
TinyCLR OS supports AWS, Azure and Google cloud, IFTTT and Adafruit IO out-of-the-box. And you can use any other platform similarly.
- TinyCLR OS code: https://github.com/RoSchmi/SC20260_AWS_Test_01
- Destop MQTT App: https://github.com/RoSchmi/MQTT_Commander_WPF
