April 25th SDK package
@ mhectorgato -
I have similar setup and my spider works great, but I do have a Powered USB 3 Hub.
This has been an outstanding issue for about 6 or so months. My laptop won’t properly recognize the device. I’ve posted screen shot after screen shot and there’s no resolution. These issue is there if I use usb or a wall wart.
@ mhectorgato - I do not think we changed anything when it comes to USB. The good news is that we have a lot more time on our hand to do specif testing or to make changes that may work around issues in specific systems/setups.
On the FEZCerbuino bee the char display is still garbled
I tried putting the using Thread.Sleep(0) that i did in the last firmware but no luck
i had to use Thread.Sleep(1) which works.
Good news is that the board must be running faster with the new firmware.
this is the code that works
using GT = Gadgeteer;
namespace Gadgeteer.Modules.GHIElectronics
    using Gadgeteer.Interfaces;
    /// <summary>
    ///     A simple character display module for Microsoft .NET Gadgeteer
    /// </summary>
    /// <example>
    ///     <para>
    ///         The following example uses a <see cref="Display_HD44780" /> object to display "Hello World" on the character display.
    ///         First, we clear the screen and set the cursor to the top left corner.
    ///         Then, we display our desired text to the screen.
    ///     </para>
    ///     <code>
    ///  using System;
    ///  using System.Collections;
    ///  using System.Threading;
    ///  using Microsoft.SPOT;
    ///  using Microsoft.SPOT.Presentation;
    ///  using Microsoft.SPOT.Presentation.Controls;
    ///  using Microsoft.SPOT.Presentation.Media;
    ///  using Microsoft.SPOT.Touch;
    ///  using Gadgeteer.Networking;
    ///  using GT = Gadgeteer;
    ///  using GTM = Gadgeteer.Modules;
    ///  using Gadgeteer.Modules.GHIElectronics;
    ///  namespace TestApp
    ///      public partial class Program
    ///          void ProgramStarted()
    ///              display_HD44780.Clear();
    ///              display_HD44780.CursorHome();
    ///              display_HD44780.PrintString("Hello World");
    ///              Debug.Print("Program Started");
    ///  </code>
    /// </example>
    public class Display_HD44780 : Module
        #region Constants
        private const byte CLR_DISP = 1; //Clear display
        private const byte CUR_HOME = 2; //Move cursor home and clear screen memory
        private const byte DISP_ON = 0xC; //Turn visible LCD on
        private const byte SET_CURSOR = 0x80; //SET_CURSOR + X : Sets cursor position to X
        #endregion
        #region Fields
        private readonly DigitalOutput BackLight;
        private readonly DigitalOutput LCD_D4;
        private readonly DigitalOutput LCD_D5;
        private readonly DigitalOutput LCD_D6;
        private readonly DigitalOutput LCD_D7;
        private readonly DigitalOutput LCD_E;
        private readonly DigitalOutput LCD_RS;
        #endregion
        // Note: A constructor summary is auto-generated by the doc builder.
        #region Constructors and Destructors
        /// <summary></summary>
        /// <param name="socketNumber">The socket that this module is plugged in to.</param>
        public Display_HD44780(int socketNumber)
            // This finds the Socket instance from the user-specified socket number.
            // This will generate user-friendly error messages if the socket is invalid.
            // If there is more than one socket on this module, then instead of "null" for the last parameter,
            // put text that identifies the socket to the user (e.g. "S" if there is a socket type S)
            Socket socket = Socket.GetSocket(socketNumber, true, this, null);
            socket.EnsureTypeIsSupported('Y', this);
            this.LCD_RS = new DigitalOutput(socket, Socket.Pin.Four, false, null);
            this.LCD_E = new DigitalOutput(socket, Socket.Pin.Three, false, null);
            this.LCD_D4 = new DigitalOutput(socket, Socket.Pin.Five, false, null);
            this.LCD_D5 = new DigitalOutput(socket, Socket.Pin.Seven, false, null);
            this.LCD_D6 = new DigitalOutput(socket, Socket.Pin.Nine, false, null);
            this.LCD_D7 = new DigitalOutput(socket, Socket.Pin.Six, false, null);
            this.BackLight = new DigitalOutput(socket, Socket.Pin.Eight, true, null);
            this.Initialize();
        #endregion
        #region Public Methods and Operators
        /// <summary>
        ///     Clears the screen.
        /// </summary>
        public void Clear()
            this.SendCmd(CLR_DISP);
        /// <summary>
        ///     Places the cursor at the top left of the screen.
        /// </summary>
        public void CursorHome()
            this.SendCmd(CUR_HOME);
        /// <summary>
        ///     This function will enable the display, clean it, and enter 4-bit mode.
        /// </summary>
        public void Initialize()
            this.LCD_RS.Write(false);
            // 4 bit data communication
            Thread.Sleep(50);
            this.LCD_D7.Write(false);
            this.LCD_D6.Write(false);
            this.LCD_D5.Write(true);
            this.LCD_D4.Write(true);
            this.LCD_E.Write(true);
            this.LCD_E.Write(false);
            Thread.Sleep(50);
            Thread.Sleep(50);
            Thread.Sleep(50);
            this.LCD_D4.Write(false);
            this.SendCmd(DISP_ON);
        /// <summary>
        ///     Prints the passed in string to the screen at the current cursor position. Note: This function will move the cursor position after.
        /// </summary>
        /// <param name="str">The string to print.</param>
        public void PrintString(string str)
            for (int i = 0; i < str.Length; i++)
                this.Putc((byte)str[i]);
        /// <summary>
        ///     Sends an ASCII character to the LCD at the current cursor position. Note: This function will move the cursor position after.
        /// </summary>
        /// <param name="c">The character to display.</param>
        public void Putc(byte c)
            this.LCD_D7.Write((c & 0x80) != 0);
            Thread.Sleep(1);
            this.LCD_D6.Write((c & 0x40) != 0);
            Thread.Sleep(1);
            this.LCD_D5.Write((c & 0x20) != 0);
            Thread.Sleep(1);
            this.LCD_D4.Write((c & 0x10) != 0);
            Thread.Sleep(1);
            Thread.Sleep(1);
            this.LCD_E.Write(false); //Toggle the Enable Pin
            Thread.Sleep(1);
            this.LCD_D7.Write((c & 0x08) != 0);
            Thread.Sleep(1);
            this.LCD_D6.Write((c & 0x04) != 0);
            Thread.Sleep(1);
            this.LCD_D5.Write((c & 0x02) != 0);
            Thread.Sleep(1);
            this.LCD_D4.Write((c & 0x01) != 0);
            Thread.Sleep(1);
            Thread.Sleep(1);
            Thread.Sleep(1);
        ///// <summary>
        ///// Turns the backlight on.
        ///// </summary>
        //public void TurnBacklightOn()
        //    BackLight.Write(true);
        ///// <summary>
        ///// Turns the backlight off.
        ///// </summary>
        //public void ShutBacklightOff()
        //    BackLight.Write(false);
        /// <summary>
        ///     Sets the module's backlight to the passed in value.
        /// </summary>
        /// <param name="bOn">True for backlight enabled, false for disabled.</param>
        public void SetBacklight(bool bOn)
            this.BackLight.Write(bOn);
        /// <summary>
        ///     Set the cursor to the passed in position.
        /// </summary>
        /// <param name="row">Row of the desired cursor position.</param>
        /// <param name="col">Column of the desired cursor position.</param>
        public virtual void SetCursor(byte row, byte col)
            var row_offsets = new byte[4] { 0x00, 0x40, 0x14, 0x54 };
            this.SendCmd((byte)(SET_CURSOR | row_offsets[row] | col));
        #endregion
        #region Methods
        /// <summary>
        ///     Sends an LCD command.
        /// </summary>
        private void SendCmd(byte c)
            this.LCD_RS.Write(false); //set LCD to data mode
            Thread.Sleep(1);
            Thread.Sleep(1);
            Thread.Sleep(1);
            Thread.Sleep(1);
            Thread.Sleep(1);
            Thread.Sleep(1);
            Thread.Sleep(1);
            Thread.Sleep(1);
            Thread.Sleep(1);
            Thread.Sleep(1);
            Thread.Sleep(1);
            Thread.Sleep(1);
            this.LCD_RS.Write(true); //set LCD to data mode
        #endregion
You guys brought up some important points about VS2010 support. We will be trying to support VS2010 as long as we can.
I am seeing something puzzling with the latest SDK.
Target Device: Cobra II
SDK: 4.2 Gadgeteer
Attached Modules: None
I created a default Gadgeteer project with the latest SDK. Around 7 out 10 times, when I try to deploy, I get a failure after the iteration count exceeds ~50. But, if I hit the reset button, while the iteration count is occurring, VS is able to attach to the debugger and deployment succeeds. Hitting the reset key works 100% of the time.
I did nothing with the default generated Gadgeteer program except change the Debug.Print() message before each deploy attempt. I did this to insure there was code that actually needed to be deployed to the device.
Has anyone seen anything like this on a Cobra II? Or any other device?
Understood - knew you had a lot your plate!
MFDeploy on the FEZ Cerbuino bee seems a little flakey.
i have 4 of them 2 went ok 2 kept giving me a device not responding message.
i eventuallyed just tried to deploy to it and it deployed fine.
Using GHI_NETMF_Configuration_Toolv003 on the cobra 2 wint flaylessly.
Will the new fangled tool work on Cerbs?
I haven’t had any problems with it.
I’ll give that a try on my non-RT tablet :wink:
Bingo.
FYI my SystemUpdate.Load() issue appears to have been solved by 4.2.10.0. Thanks GHI!
Using the new tool I was able to update the firmware just fine!
One hurdle down and another appears.
Am able to get the device capabilities, but can’t deploy.
What about loading a simple console ā€œhello worldā€ app?
What if you hit reset when loading?
What if you used WinUSB drivers?
Am using WinUSB
Reset doesn’t seem to help
Simple app (just the Cerbuino on the designer) doesn’t deploy
Console app fails to deploy as well
What if not using winusb?
I’ve read most of the messages of this post but I think I’ve missed some elements. From now it seems that GHI will only supports VS2012. Do you know if VS2012 can be installed on Vista?
Will give it a try later on today.
