Sorry if this is out of place. Please delete this if so…
I am a bit confused on what will work with what OS in the near future. It looks to me that you will no longer be supporting VS2010.
No right or wrong - I just do not want to change my ‘day to day’ PC to Windows 8. Frankly, I have one PC with Windows 8 Pro and I do NOT like using Windows 8.
NO… I have nothing against change, I just don’t like using it.
Will I remain compatible with your future software releases if I install VS2012 Express on my Windows 7 64 bit?
I removed everything before setting up a test machine and installed as suggested.
But now I don’t have any references to 4.2 anymore and my GHI devices have 4.2.10 after updating:
Error 1 Cannot deploy the base assembly ‘mscorlib’, or any of his satellite assemblies, to device - USB:EMX twice. Assembly ‘mscorlib’ on the device has version 4.2.0.0, while the program is trying to deploy version 4.3.0.0
@ David@ Emrol - In your project properties, try switching it from 4.3 to 4.2 and see if that helps. It looks like it might be trying to deploy a 4.3 project instead of 4.2.
New SDK adds project templates for VS2012 only so you will not see NETMF related projects in VS2010. You can still build apps for 4.1, 4.2 and soon 4.3 using VS2012.
@ architect - Thanks, I would like to develop using the latest SDK and VS 2012, but I’m still confused about what I need to install and un-install if I want to continue developing for Cobra 1 and Panda II?
On Cerberus with VB.net I get strange characters with the PrintString(“Adresse”) function.
I’m using VS 2012, last SDK and my board is flashed with firmware 4.2.5.0
My other question is about something specific to VB. With that language, you can declare a property in a class simply by coding something like :
Property MyProperty as string
The debugger in Visual Studio 2012 does not work properly with this kind of declaration. The following message appear in ouput Window and the debugger stops :
Instead, if I declare my property like the following code it works :
Public Property MyProperty As String
Get
Return m_MyProperty
End Get
Set(value As String)
m_MyProperty = value
End Set
End Property
Private m_MyProperty As String
I don’t know why and I don’t know if I’m alone. What I’m sure is that it worked well with VS 2010. Could you do a quick test?
Updating Hydra firmware was not successful on Win 8. I had to go on a Win 7 pc and I got it right.
I’ve tried both options, boot.ini, pin8-10 short, but no go. This had happened on 3 Hydra boards and 2 different win8 pc. On the Win 7 all Hydra updated correctly.
May be a problem on my PC but I never had problem before.
PS: Fez Spider, Fez Cobra II, G120HDR2, Fez Cerberus updated correctly on Win 8 without any issue.
