Hi all,
When I attempt to add any of the following modules into the designer, I receive the following message, any ideas? I’ve tried reinstalling everything.
[quote]The module could not be added:
A required library could not be found
[/quote]
Ethernet_J11D
UsbHost
WiFi_RS21
Camera
CAN_DW
Obviously I’m not trying to use all these at the same time xD!
I’m having the exact same issue with the UsbHost module, I looked at the GadgeteerHardware.xml and it was significantly different from any of the other modules. So I changed the xml to more closely match the RS232 module.
It seems to be working now, the lines that caused the issue were:
<!-- If your module relies on another assembly, then list it here (and see the msm.wxs file since you need to include it in the installer too), e.g.: -->
<Assembly MFVersion="4.1" Name="GHIElectronics.NETMF.Hardware" ErrorMessage="A required library could not be found."/>
<Assembly MFVersion="4.1" Name="GHIElectronics.NETMF.IO" ErrorMessage="A required library could not be found."/>
<Assembly MFVersion="4.1" Name="GHIElectronics.NETMF.System" ErrorMessage="A required library could not be found."/>
<Assembly MFVersion="4.1" Name="GHIElectronics.NETMF.USBHost" ErrorMessage="A required library could not be found."/>
<Assembly MFVersion="4.2" Name="GHI.Premium.Hardware" ErrorMessage="A required library could not be found."/>
<Assembly MFVersion="4.2" Name="GHI.Premium.IO" ErrorMessage="A required library could not be found."/>
<Assembly MFVersion="4.2" Name="GHI.Premium.System" ErrorMessage="A required library could not be found."/>
<Assembly MFVersion="4.2" Name="GHI.Premium.USBHost" ErrorMessage="A required library could not be found."/>
<!-- Use the ExtraLibrariesRequired element if this module requires specific firmware libraries to be provided by the mainboard, and so is limited to a subset of mainboards. -->
<ExtraLibrariesRequired>
</ExtraLibrariesRequired>
I downloaded the files this morning and tried uninstalling and re-installing. It looks like the install files were modified on the 14th but the change log indicates no updates. If anyone has any ideas let me know.
I kinda spoke to soon, I had quickly created a project to see if I could add those elements to the designer, which worked, but then “using Gadgeteer.Modules.GHIElectronics;” produced:
After mucking about, I uninstalled everything again, installed again, and my original problem happened again. So, I re-installed the old 4.1 MS\GHI SDK.
I have the same problems using FEZ Spider with NETMF 4.2, but only with the following modules:
Ethernet_J11D
WiFi_RS21
Other modules could be added without problems. I have not installed “GHI NETMF v4.1 and .NET Gadgeteer Package Sep. 14, 2012” (step 4), since I have installed only “Microsoft .NET Micro Framework 4.2 QFE2 SDK”. Looking at the “GadgeteerHardware.xml”, for Ethernet_J11D and WiFi_RS21, both of the modules mention “GHIElectronics.NETMF.Net” as required assembly:
<Assembly MFVersion="4.1" Name="GHIElectronics.NETMF.Net" ErrorMessage="A required library could not be found."/>
<Assembly MFVersion="4.2" Name="GHIElectronics.NETMF.Net" ErrorMessage="A required library could not be found."/>
However, I could not find it. Interestingly, other modules, e.g. “Camera” refer to “.Premium.” assemblies for NETMF 4.2, but stays with “.NETMF.” for 4.1:
Commenting out references to required libraries in the “GadgeteerHardware.xml” for Ethernet_J11D module made the trick:
[b] <!-- [/b] <Assembly MFVersion="4.2" Name="GHIElectronics.NETMF.Net" ErrorMessage="A required library could not be found."/> [b]-->[/b]
then did you do what fixed this for the person who posted the thread?
[quote]I’d start by uninstalling all NETMF, Gadgeteer, & GHI bits and reinstalling. Sounds like your install had a problem.[/quote] Remember the order is important
