It seems that Y sockets 15-17 which are also used for screen can’t be used.
My PulseCount module always gives me 0 whereas when on socket 1, it works well.
Am I missing something such a flag to deactivate screen ?
My firmware is up to date.
@ maverick78 - Is it a console program? Do you have some code that can be shared? What are you connecting to the PulseCount module? Is that correctly connected?
When I plug the screen, it’s all white, nothing more.
I’ve tried GHIElectronics.NETMF.Hardware.Configuration.LCD.Set(LCD.HeadlessConfig); but nothing changed.
@ maverick78 - How do you have them hooked up in the designer? You do not need to declare a HeadlessConfiguration if you are using Gadgeteer. Gadgeteer automatically disconnects the RGB displays depending how it is connected in the designer.
We have found the problem. The driver does not currently set the state of the enable pin. On the LCD pins, we pull those down by default which disabled the count. This will be fixed in the next SDK. In the mean time, you can create a digital output on the socket you are using on pin 5 and set it high.
