Hi all, Is there a way to use XmlReader with a string containing the XML document ?
Yes,
You can put string into a stream and use the stream object with XmlReader.
Create the XmlReader from a Stream object like so:
string s = "Some valid XML";
byte[] bytes = Encoding.UTF8.GetBytes (s);
MemoryStream ms = new MemoryStream (bytes);
XmlReader reader = XmlReader.Create(stream);
Word of warning - XML is a memory hog and you can quickly eat up all the smaller FEZ boards have to offer.
Thanks you very much guys
I used XML as well in the past. I now moved to JSON, feels much lighter
Json makes it easier for javascript to parse. Xml is still a better choice if you want something universal.
