Hi, I am having some problems writing both image and text data to SD card. The following code uses various sensors to log text data, and write it to SD card as a .csv file. It also uses a PIR sensor controlled camera to take pictures and write them to the same SD card. When I run the code and leave the PIR sensor undisturbed it runs fine, writing the text data as expected. However, as soon as i disturb the PIR sensor to take a picture, I get an error #### Exception System.IO.IOException - CLR_E_INVALID_DRIVER (1) ####
the first picture writes to the card ok, but no further data (text or image) is placed on the card. How can i solve this issue? Am I confusing the SD card by expecting it to write two types of data simultaneously? thanks and sorry for the long message!
namespace sdcardtexttemplog
public partial class Program
private GT.Timer _getReading = new GT.Timer(40000);
private double _t1;
private double _h;
private double _lx;
private double _p;
int pictureIndex = 1;
FileStream myFile;
StreamWriter stream;
TextWriter writer;
GT.StorageDevice storage;
GT.Timer timer;
void TheLoop()
Debug.Print("The Eagle Has Landed");
sdCard.MountSDCard();
motion_Sensor.Motion_Sensed += new Motion_Sensor.Motion_SensorEventHandler(motion_Sensor_Motion_Sensed);
camera.PictureCaptured += new Camera.PictureCapturedEventHandler(camera_PictureCaptured);
if (sdCard.IsCardMounted)
storage = sdCard.GetStorageDevice();
Debug.Print("SD CARD NOT MOUNTED PROPER");
if (sdCard.IsCardMounted && storage != null)
myFile = storage.Open("data" + ".csv", FileMode.Create, FileAccess.Write);
writer = new StreamWriter(myFile);
writer.Write("Temp");
temperatureHumidity.MeasurementComplete += new GT.Modules.Seeed.TemperatureHumidity.MeasurementCompleteEventHandler(temperatureHumidity_MeasurementComplete);
temperatureHumidity.StartContinuousMeasurements();
barometer.MeasurementComplete += new GT.Modules.Seeed.Barometer.MeasurementCompleteEventHandler(barometer_MeasurementComplete);
barometer.ContinuousMeasurementInterval = new TimeSpan(0, 0, 0, 40);
barometer.StartContinuousMeasurements();
_getReading.Tick += new GT.Timer.TickEventHandler(_getReading_Tick);
_getReading.Start();
void temperatureHumidity_MeasurementComplete(GT.Modules.Seeed.TemperatureHumidity sender, double temperature, double relativeHumidity)
_t1 = temperature;
_h = relativeHumidity;
void barometer_MeasurementComplete(GT.Modules.Seeed.Barometer sender, GT.Modules.Seeed.Barometer.SensorData sensorData)
_p = sensorData.Pressure;
void _getReading_Tick(GT.Timer timer)
_lx = lightSensor.ReadLightSensorPercentage();
Debug.Print("Temperature : " + _t1 + " degrees ");
Debug.Print("Humidity : " + _h);
Debug.Print("Light : " + _lx);
Debug.Print("Pressure : " + _p);
using (FileStream myFile = File.Open("\\SD\\_data.csv", FileMode.Append))
byte[] logMsg = UTF8Encoding.UTF8.GetBytes("temperature " + _t1 + " degrees" + "," + _h + "," + _lx + "," + _p + "," + "\n");
myFile.Write(logMsg, 0, logMsg.Length);
myFile.Flush();
void motion_Sensor_Motion_Sensed(Motion_Sensor sender, Motion_Sensor.Motion_SensorState state)
camera.TakePicture();
void camera_PictureCaptured(Camera sender, GT.Picture picture)
try
String filename = "picture_" + pictureIndex + ".jpg";
sdCard.GetStorageDevice().WriteFile(filename, picture.PictureData);
pictureIndex++;
sdCard.UnmountSDCard();
catch
Debug.Print("broken");
