Work stage - FEZ Domino
Hello,
I’m doing an internship at a company and I can work, Connect a load cell to an analog port of a device FEZ Domino language C # .NET Microframe Work.
The job is basically to read the analog input into a loop, and convert volts / Current in Newton to appear in the display.
How do I read the analog input in a cycle?
Greetings
you first should read the e-book, [url]http://wiki.tinyclr.com/index.php?title=Category:Beginner_Guide_ebook[/url] that way you can learn to do this yourself. There’s plenty of examples in there that you can use as the basis for your app.
thanks for the tip, if you later have a problem and need help I put here. thanks
