Found debugger!
Assembly: Microsoft.SPOT.Native (4.4.0.0) (1248 RAM - 7468 ROM - 4862 METADATA)
AssemblyRef = 4 bytes ( 1 elements)
TypeRef = 88 bytes ( 22 elements)
FieldRef = 0 bytes ( 0 elements)
MethodRef = 60 bytes ( 15 elements)
TypeDef = 368 bytes ( 46 elements)
FieldDef = 220 bytes ( 110 elements)
MethodDef = 244 bytes ( 122 elements)
Attributes = 0 bytes ( 0 elements)
TypeSpec = 0 bytes ( 0 elements)
Resources = 72 bytes ( 9 elements)
Resources Files = 8 bytes ( 1 elements)
Resources Data = 747 bytes
Strings = 1099 bytes
Signatures = 618 bytes
ByteCode = 535 bytes
Assembly: mscorlib (4.4.0.0) (4344 RAM - 42076 ROM - 22412 METADATA)
AssemblyRef = 0 bytes ( 0 elements)
TypeRef = 0 bytes ( 0 elements)
MethodRef = 0 bytes ( 0 elements)
TypeDef = 1160 bytes ( 145 elements)
FieldDef = 300 bytes ( 149 elements)
MethodDef = 1828 bytes ( 914 elements)
TypeSpec = 16 bytes ( 4 elements)
Resources = 232 bytes ( 29 elements)
Resources Files = 16 bytes ( 2 elements)
Resources Data = 437 bytes
Strings = 2774 bytes
Signatures = 3100 bytes
ByteCode = 16043 bytes
Assembly: con44 (1.0.0.0) (280 RAM - 824 ROM - 422 METADATA)
AssemblyRef = 8 bytes ( 2 elements)
TypeRef = 44 bytes ( 11 elements)
MethodRef = 40 bytes ( 10 elements)
TypeDef = 24 bytes ( 3 elements)
FieldDef = 4 bytes ( 2 elements)
MethodDef = 12 bytes ( 5 elements)
Resources = 16 bytes ( 2 elements)
Resources Data = 13 bytes
Strings = 94 bytes
Signatures = 62 bytes
ByteCode = 123 bytes
Resolving.
Total: (4824 RAM - 50368 ROM - 27696 METADATA)
AssemblyRef = 12 bytes ( 3 elements)
TypeRef = 132 bytes ( 33 elements)
MethodRef = 100 bytes ( 25 elements)
TypeDef = 1552 bytes ( 194 elements)
FieldDef = 524 bytes ( 261 elements)
MethodDef = 2084 bytes ( 1041 elements)
DebuggingInfo = 1048 bytes
Resources Files = 96 bytes ( 4 elements)
Resources = 320 bytes ( 40 elements)
Resources Data = 1197 bytes
Strings = 3967 bytes
Signatures = 3780 bytes
ByteCode = 16701 bytes
GC: 1msec 270672 bytes used, 3923412 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 3923412 bytes
Type 17 (ASSEMBLY ): 5880 bytes
Type 1E (BINARY_BLOB_HEAD ): 264264 bytes
Type 28 (MEMORY_STREAM_HEAD ): 36 bytes
Type 29 (MEMORY_STREAM_DATA ): 396 bytes
GC: performing heap compaction…
Ready.
‘Microsoft.SPOT.Emulator.Sample.SampleEmulator.exe’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.4\Assemblies\le\mscorlib.dll’, Symbols loaded.
‘Microsoft.SPOT.Emulator.Sample.SampleEmulator.exe’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.4\Assemblies\le\Microsoft.SPOT.Native.dll’, Symbols loaded.
‘Microsoft.SPOT.Emulator.Sample.SampleEmulator.exe’ (Managed): Loaded ‘C:\Users\Peter\Documents\Visual Studio 2013\Projects\con44\con44\bin\Debug\le\con44.exe’, Symbols loaded.
OEM : Microsoft Copyright (C) Microsoft Corporation. All rig
SDK : 4.4.0.0
Done.
Hello World!
The thread ‘’ (0x1) has exited with code 0 (0x0).
The program ‘[5504] Micro Framework application: Managed’ has exited with code 0 (0x0).
