The scenario is the domino(with Xbee) send a packet to the Spider(has xbee also) every 5 seconds.
When the spider receive the packet then taking a picture and display the image.
But the image can’t display on time. it always has a delay time for displaying picture.
The screen shows the picture which is not the current picture.
public partial class Program
public static byte[] input = new byte[12];
GT.Timer timer = new GT.Timer(3000);
//string test = "test";
var font = Resources.GetFont(Resources.FontResources.small);
xBee.SerialLine.Open();
camera.PictureCaptured += new Camera.PictureCapturedEventHandler(camera_PictureCaptured);
timer.Start();
void camera_PictureCaptured(Camera sender, GT.Picture picture)
display.SimpleGraphics.DisplayImage(picture, 5, 5);
int count = xBee.SerialLine.Read(input, 0, input.Length);
if (count > 0)
char[] chars = Encoding.UTF8.GetChars(input);
string str = new string(chars, 0, count);
Debug.Print(str);
camera.TakePicture();
Debug.Print("picture captured");
I guess you are wondering: “Why it does not work as expected?”
Actually, I do not see where do you set the timer to be 5 second… May be the delay is coming from the size of your picture, May you resize it and see if if changes the delay.
Can you make a simple program that only captures one picture and displays it? Measure the time it takes and print it (don’t use breakpoint as it might slow it down). Also you could try something like this (sorry if it doesn’t compile but i was using notepad).
GT.Picture picture;
AutoResetEvent pictureReady;
pictureReady = new AutoResetEvent(false);
camera.PictureCaptured += (s,p) =>
picture = p;
pictureReady.Set();
var startTime = DateTime.Now;
pictureReady.WaitOne();
Debug.Print(DateTime.Now.Subtract(startTime));
Dear Gralin:
I test your code.
The output shows "Camera ERROR : Unable to take picture. Camera is not ready. Is the Camera connected?"
But I think the camera is ok, because I can run my other application.
And I don’t understand what it mean “+= (s,p) =>”.
Thanks for your help.
I have no experience with Gadgeteer boards/modules but if the camera is not ready at the start maybe add some delay at the beginning or create a timer and make it trigger your code.
It need 1.3 seconds for pushing the button, take the picture and shows on the display.
So the remote Xbee send a packet to the spider every 5 seconds then the spider takes the picture and shows the picture should be work in this time interval.
But it is not.
Something wrong in my code.
Maybe the problem is the timer?
I don’t know.
you need to always break down the testing of this kind of thing into modules.
Does the periodic sending of the signal from one device to the other, and only doing debug.prints, work reliably? If not, then fix that and then move forward.
Does a periodic “take picture” work reliably on a single board with the camera? If not, then work on that issue and then move forward. (remembering that there’s the big thread on “Type B” cameras and issues that are known to only allow cameras to take a few pics before going into a failure state).
Does a periodic “take picture and display” work reliably on that single board? Again, make that work reliably and then move forward.
Then, you have all the components working individually and you can mash them all together. Any issue you have mashing them is only caused by the mashing, not anything else, and is much easier to diagnose for both you and us.
Thank you brett, I will check it under your comments. Thanks Gralin, I will test your code tomorrow.
My english is not very good so sometimes hard to explan exactly. My programming ability
is not so good also. Thank you all are patiently to help me.
Thanks your driver.
I can combine Xbee and NRF24L01Plus using Domino and Spider to do a simple two hop transmitting. It demos a simple mixing networks.
I will put an example to the code share page.
My example works fine, but my programming skill is not very good.
So,could you help me to optimize the code, then I can put in the page. Maybe useful for some newbies.
If you could , how to send my code to you?
Thanks.
Timers invoke your code after given time no matter if the previous invoke already ended. This can cause errors when your invoked method takes more time then timer time. This is why i always set the timer to run only once and restart it at the end. This way i make sure i don’t get parallel calls to my method. In regular .NET you would use
new Timer(MyMethod,3000,-1);
The -1 in the third param informs the timer not to repeat after one invoke.
You will find my e-mail on my forum profile page. Feel free to send me the code and I’ll try to contribute.
