The new all in one installer (.NET Gadgeteer Package) worked fine for me on Vista. However, when I try to run it on XP after successfully following the same first two stages from your instructions below, I get an error from your .NET Gadgeteer Package saying “Compact Framework 2 could not be found” and asking me to install it. Despite the fact that the Framework 4.1 was definitely installed.
I am writing a book about Gadgeteer and wanted to make sure that the install instructions worked on XP as well as newer Windows versions.
We need to know if the problem is in one of the installers or in the software we made that invokes them. Can you please run each installer manually and tel us if you have any problems?
Welcome to the community and we look forward to seeing your book.
