Is it possible to run Windows Embedded on the GD400 Module Main Board? If so does GHI provide a BSP for it? Can it support the net compact framework as well?
I ask because I am not quite sure the .NETMF will be powerful enough to do what I am trying to do, which is to parse frames from an IP camera and send them out to a server. Frames would be mjpeg format.
Anyone have any experience of .NETMF running GHI boards and doing this?
