Hi guys,
I tired using LCDs from Nokia, but found it all but impossible to de-solder the connection from the phone, to make a breakout board with 0.25mm lines ( as they would each out ) and, most impossible, to solder that connector to my board. So, the best solution would be to get an LCD already fixed to a breakout board. ![:slight_smile: :slight_smile:](https://forums.ghielectronics.com/images/emoji/twitter/slight_smile.png?v=12)
I found this two and just wanted to ask here, to be sure that they’ll work with panda2 ?
Thanks! ![:slight_smile: :slight_smile:](https://forums.ghielectronics.com/images/emoji/twitter/slight_smile.png?v=12)
It uses same ILI9325 LCD controller as Fez Touch. You will have to do some wiring, though.
Why not using Fez Touch?
http://www.ghielectronics.com/catalog/product/262
Thanks! But if it uses the same controller, what sort of writing do you think would be needed?
Not a big deal. I just meant that you will probably not be able to just plug it in into Panada II’s 40 pin header and use it as is. ;D
same controller, not same pinout…and costs more than FEZ Touch ![:slight_smile: :slight_smile:](//forums.ghielectronics.com/images/emoji/twitter/slight_smile.png?v=5)
If I understand right, all it takes would be just to connect the right pins to the right holes of Panda, right?
Its 2.8" , while FEZ Touch is just 2.4" and I can’t seem to find them in stock of my reseller in EU. ![:slight_smile: :slight_smile:](//forums.ghielectronics.com/images/emoji/twitter/slight_smile.png?v=5)
Cool!
only $29.80 and 3.2" + touch!
It also uses that ILI9325 controller?
ILI9327- is very similar to ILI9325
That way if I’ll connect the right pins, it’ll work?
@ Roger1981:
Yes, it will work. However the initialization may be a bit different than the FEZ touch. If you download this
http://henningkarlsen.com/electronics/a_l_itdb02_graph16.php
you will find some example code for this display. Although it’s written in C++ for the Arduino you can extract the information necessary.
I ordered the 2.4" display from iTead about a month ago. It took almost 3 weeks for it to clear customs to get into the US. I just ordered one of these wide screen displays so I expect it will also take about 3 weeks to receive it ![:cry: :cry:](https://forums.ghielectronics.com/images/emoji/twitter/cry.png?v=12)
Regards,
Synapsys
Absolutely!
Changing initialization code will be a very simple thing. We can always help you with that. ;D
Thanks guys!
I’ll order a few screens from them.
