Any examples of getting wifi working using 4.3?
Is 4.3 a supported version? Is it stable for commercial use?
The existing examples appear to be for 4.2.
@ anthonys -
Is 4.3 a supported version? Yes
Is it stable for commercial use? Yes but initialization has to be done during startup (if timing is critical).
Thanks David/. Where is example code for wifi? The examples only appear to apply to 4.2 sdk?
Not sure if there is a correct sample online but i did copy some (maybe not all) code from my project to show you the main parts.
Wifi = new WiFiRS9110(SPI.SPI_module.SPI2,GHI.Pins.G120.P1_27 , GHI.Pins.G120.P2_13, GHI.Pins.G120.P1_28, 4000);
NetworkChange.NetworkAddressChanged +=NetworkChange_NetworkAddressChanged;
NetworkChange.NetworkAvailabilityChanged +=NetworkChange_NetworkAvailabilityChanged;
if (Wifi.Opened == false )
Wifi.Open();
//only when it's actualy open !!!
if (Wifi.Opened == true)
if (!Wifi.NetworkInterface.IsDhcpEnabled)
// always use DHCP on WIFI
Wifi.NetworkInterface.EnableDhcp();
Wifi.NetworkInterface.EnableDynamicDns();
// scan to see if SSID is availible
GHI.Networking.WiFiRS9110.NetworkParameters[] WifiScanResult = Wifi.Scan();
for (int i = 0; i < WifiScanResult.Length; i++)
if (WifiScanResult[i].Ssid == Wifi_SSID)
SysLogOut("", "Join Wifi " + Wifi_SSID + " -" + WifiScanResult[i].Rssi.ToString() + "db NT" + WifiScanResult[i].NetworkType.ToString() + "SM" + WifiScanResult[i].SecurityMode.ToString() + "CN" + WifiScanResult[i].Channel.ToString()) ;
Wifi.Join(WifiScanResult[i].Ssid , Wifi_Key);
break;
static void NetworkChange_NetworkAvailabilityChanged(object sender, Microsoft.SPOT.Net.NetworkInformation.NetworkAvailabilityEventArgs e)
Debug.Print("Network has changed! ");
static void NetworkChange_NetworkAddressChanged(object sender, EventArgs e)
Debug.Print("New address for the Network Interface ");
